I'm willing to bet a simple 600w should be plenty for this as long as you aren't trying to run some serious graphics too
did they change from a 92mm fan to 120mm? it's about damn time
yes they did, that's one of the reasons why they could push the tecs further (on top of the new arrangement, that helped quite a bit too supposedly)
he's saying the tcm (which controls the unit, allows you to control how strong the tecs will get, the pump, fan, the whole works, kinda like the gfroster or freezepack phase change controllers), but I don't think he's ever actually messed with one to know what he's talking about, half the thread he's just been trolling it
Jigsaw
you have no idea what your talking about.IF you want to read my and my partners review go to www.nordichardware.com It wsill be posted either Thurs or Fri. We have 12,000 members and i belive we know what we are doing.
Itr doesn't seem like you are using your FreeZones to their full potential as evidenced by your overclocks. Actually, your overclocks lead me to believe that you really don't have any skill what so ever. 3500MHz on an E6850 and 3400MHz on a QX6850 G0? Regardless of what you plan to do with your chips you can push them much higher than that on near stock volts. This is Xtreme Systems and your signature takes up enough space that it should at least be worth while to read. Show me you know what you are talking about and prove me wrong. As of now I officially declare you a n00b with too much money.
Hey Mate. I dont think the product is cool, to expensive. But WTF. Admins just told you NOT to post here. And still you call people n00bs.
XS dosent allow stuff like that, it is a violation of forum rules. ;)
So Edite you reply and stay here on the site :yepp: :up:
BTW smile man ;)
High fan load testing below 35C QX6800 3520MHz is not excellent? :confused:
Frequency means everything with heat output actually, just voltage effects the P more.
FWIW, the CoolIT Freezone was known to get sub-ambients with the B3 stock QX6700. I didn't see it pushed to above 3.5GHz though, but the one I saw was running a watercooling 2 separate loops (NB/SB/MosFETs/VGA-CPU) triple 120 rad setup with chilled water (ambient was 18℃ in FL) and still could not go above 3.35GHz on the EVGA 680i (24/7 stable below 55C full 12hr load) and the CoolIT Freezone managed 3.46GHz fully stable with very low temps (too long ago to remember what they were but definitely ≤50C). At that time, it was the best air/water cooling for the quads and they weren't even supported past 200W-ish. They would definitely be better now, especially because using the control center the fan could be adjusted to very quiet before but temperatures would shootup near mid-end air cooling when you did that back then (that was the low power settings IIRC) and now the fan has been replaced with a 120CFM fan instead of the 65CFM.
Neat how they kept the overall weight consistent too.
Stan/Andreas: Would've been good to be able to compare it with the difference over the Freezone, but great review nevertheless. :)
And there's nothing more stupid than that. ;)
wasnt it supposed to run a quad at 4ghz?
didnt they claim this at cebit or the games convention or something?
Jigsaw stop trolling the thread, you were even told by perkam not to post here anymore and yet you don't seem to care
Dude, he was told to only do 3.5ghz since his is still just an engineering sample in the first place.
Secondly, he did 3.5ghz on a qx6800, I don't know where you're getting the e6850 and qx6850 from.
Not to mention, who are you to call him a n00b? We haven't seen you produce anything worthwhile but flame people. He was given an engineering sample before anyone else because coolit has worked with him on multiple occasions and trusts him with their products. They don't just give it to anyone. If you manage to get an elite yourself, then go ahead, show us what you're made of. But until then, lay off
Lastly, he has a striker because you can't use sli on intel chipsets, what would be the point of buying a great p35 board when he already had the two ultras?
Freezone only supported 175W dissipation and that was presented at CEBIT 07, so this should do far better.
well, here's the thing, the main enhancements are just layout changes and a new pump in order to allow the unit to make more use of the tecs as a whole. So while performance does increase, I wouldn't say it's radical
is this a good cooler for Conroes?
yes, definitely. Kentsfield, I wouldn't try pushing the voltage, but conroe no doubt about it
my problem is "WHY" coolit says to not go beyond 3.5 mhz...i would think from a technical stand point you would want to confirm the limits of this pre-production unit....wouldn't anyone want to know the limit of the unit...so...if i am right, they don't want find out...OR...let it slip out that the elite unit has inadequacies...this might be perceived but never the less has to be considered as a negative.
i was about ready to buy one...but...i am not sure any more unless i see definitive data that it says it can handle more than 3.5 Ghz....my gosh, i can put my TRUE 120 (dual fan) on that cpu and get the same results...maybe higher temps but it can do the JOB!
Don't know, but his striker died anyways, so that's why we haven't pushed any further after that on our own
you mean to tell me he can not find another suitable board to test the elite on????
he has an asus maximus now, but I guess the tests wouldn't be consistent. I dunno, ask him yourself
i find your answer disturbing since you started this thread...i would think that you could provide the information or urge him to come forth about his intentions to test the elite on the maximus...my gosh, if he can not attain 3.5Ghz on the maximus board, there is no hope for him at all in doing any justice to the elite cooler.
I haven't spoken with him in a while, we've both been very busy, I'll send him an email, and if you like, he's doctor_death if you want to pm him about it.
I'm pretty sure the elite can do more than 3.5ghz, especially when he's modded regular freezones to go past that (I think he's done 4ghz on quad before on one of his modded freezones, using the stock tec system [ie not too serious mods])
