I went to the Paint shop Far Far away ( the only guy that knows what i need) and he fixxed me up. Explained to me about the different grades of tints he had and hooked me up with some 901 white - which is very very weak and sprays like a dream !
I have put some of your quote in bold... It is very true! and i know exactly what you mean. But that concept just hasn't caught on over here! no bugger knows what i want. and to be frank... they just don't care! Honestly... trying to convince the paint suppliers that they DO have the product that im after in their paint system... they just have to steer off the beaten track a bit and mix it up by eye. but they wont have any of it !
As i say... theres only one supplier i know who has a clue lol.
Update:
Well, Ive been grinding away again this weekend and I'm pleased to say that the side panel is pretty much finished :)
I'M not going to add the colour until the res of the case is ready for colour though. SO only black and white for now.
So I learned one thing last night - Don't paint at 2AM, or was it 1AM ? I'm not entirely sure as the clocks went back.
I'm leaving the little angel and the big daddies arms alone this time, and concentrating on the helmet.
the thick end of yesterday was spent finding a decent way to do the tubes that attach to the helmet. A little bit of artistic license ( that is the posh way of saying making it up ) had to come into play as the reference picture is a little lacking in information for the round part where the tube goes into. So I have just painted it to give the effect. Its not a 100% match to the original, but sometimes with pieces like this. it looks better if its a little different.
http://img151.imageshack.us/img151/9...1mediumnn4.jpg
It all looks a little rough here, the round parts are defined later.
A little bit of fine line tape helps me create the shape of the helmet and provide a hard edge to spray against. Again It's just basic shapes we're after here.
Now this is when disaster struck.
http://img100.imageshack.us/img100/3...2mediumfv7.jpg
In case you missed it
http://img98.imageshack.us/img98/445...3mediumot7.jpg
Now believe it or not. This is not such a bad thing. It could have been worse though !
The best thing to do in a situation like this is to just leave it to dry. If i was to follow my instinct and wipe it it would have been well and truly ruined! SO i just carry on painting and come back to it the next day and simply sand it off.
working on the right hand side of the helmet now and adding some texture to the helmet too. You will notice the rough shape of the pressure gauge on the tank. I was never sure if i wanted to put it in or not so i only ever roughed it in... Now you see it...
http://img145.imageshack.us/img145/9...7mediumtq5.jpg
Now you don't. :) Much better Don't you think? - that whole artistic license thing again :)
I need to sort that bit ont he top of the helmet out too :)
I have also decided not to include any of the windows and architecture in the scene. The reason for this is simply that when i put the panel onto the rest of the chassis, all of those window panel lines and metal bars would have to 'go somewhere' So i am just not including them.
Now what i tend to do now on a project like this is to finish off any major parts of this panel, then put it to one side and come back to it at the end.
When you have been starting at the same piece for days on end. you tend to miss mistakes... SO after a few days of not looking at it. when i go back to it any mistakes will stand out and i can correct them and put the final touches onto the artwork
Next stage..
Rapture!
