Thanks for the info mate, seeing your builds has been a big help and inspiration.
One more question is there any reason why you use 0.37/0.9mm cap tube instead of 0.31/0.8mm
Thanks so much :)
0.8mm doesn't look like to be suitable with 20kbtu/h+ compressors. At least that's what I guess... I've encountered a matter of very HSP with 0.8mm and the 25kbtu/h compressor used in my 3-stager 1st stage. Captube was 1.9m long, and formerly set for a 10kbtu/h. After moving for the 25kbtu/h beast, captube became a matter.
Under windows with today's tuning.
Idle : -117.8C evap (-60.3C HX out)
http://www.ixtremtek.com/images/Asus...o/-117,8Ca.jpg
Just for fun; final tuning won't be that cold. :)
flares are one shot, second you torque the bolt, if you unmount it you must remake the flare. Technicaly you can re-use a flare 2 more times but it should be avoided.
Sorry buddy... why are you talking about flares? :) Wrong thread?
Oh ok... that was on January the 12th... I forgot :D
Thanks for your reply anyway :toast:
Ah, that is understandable lol.I just saw this thread at the top and thought it was realitively new.
The old 1.9kW home-repaired condenser is leaking again... I've ordered a Luve 5.2kW one to be used as a replacement. Guess it'll fit much better.
LOL, that's a huge condensor, before. :D I guess from cold_ice? Looking forward to it!
5.2 kw :eek: man You beat me with mine 3.6 kw :D
so what captube on 2nd stage are You using now ?
a big condesor isn`t always good, i made this experience in my huge cascade. you may have to switch one fan off (when possible) or control fan speed.
Just use a fan cut in, cut in at desired max pressure, cut out at a lower one.
New condenser installed.
Tried it quickly and got -101C CPU socket temp during Spi 32M à 5.8GHz @1.81v... :D That's damn good. I'm gonna setup a Win XP to perform some 3D benchies.
http://www.ixtremtek.com/images/45KbtuBEa.jpg
http://www.ixtremtek.com/images/45KbtuBFa.jpg
http://www.ixtremtek.com/images/45KbtuBGa.jpg
I've played a bit with this cascade. It holds load pretty well: -112C idle, -110C Spi32M (HX @-62C). :)
http://img509.imageshack.us/img509/2...tre1copiev.png
http://img509.imageshack.us/img509/7...g8350copie.jpg
Nice job!! My cascade doing similar temps.
Thx mate. :) Any pics of yours?
hehe wrong thread sdumper ;)
lol :D sdumper, my Grosse Bertha is doing a bit lower temps! Based on socket temp, I'd say about 15C less at equivalent load.
Thanks guys.
Ryba, did you use captubes? If yes, what lengths?
lol ok thx anyway :D
