3DMark Score 10190 3DMarks
SM 2.0 Score 4720 Marks
SM 3.0 Score 4834 Marks
CPU Score 2226 Marks
CPU Opteron 170 @ 3.0 GHZ
Nvidia 8800GTX @ 576/900
other details in sig
Typhon
Typhon
3DMark Score 10276 3DMarks
SM 2.0 Score 4701 Marks
SM 3.0 Score 4681 Marks
CPU Score 2417 Marks
X2 Brisbane 5000+ @3154MHz@1.350V@Air + XFX 8800GTS eXTREME @661/2020MHz, 320Mb model
http://img90.imageshack.us/img90/8082/mark06fj8.th.jpg
i am going to buy another 8600gt and put them into sli. let's see if i can break 10000. I heard it goes up to 9500 but with little bit of OC and new driver, i think it is possible.
@Raptor22... to qualify to be on scorebord you have to be using an AMD CPU...
pslee if possible sell 8600gt and instead buying another buy outright a 8800GTS 320MB... 640mb verisions are not worth it too close to 8800gtx prices for not much gain!
So whens sum1 with a Amd/8800Ultra gona come out of the woodwork?!? :shrug:
probably not gonna happen...:D
We will see. There are some cheap 8600GT on ebay/amazon, so that is more affordable than getting 8800gts/gt. I've also heard the new version is coming out for 8800gts. I don't want to spend $300+ for soon be EOL.
CPU 14x250 (3500)
Mem 1000 5-5-5-15
2900XT 875/2002
3DMark Score 11535 3DMarks
SM 2.0 Score 4985 Marks
SM 3.0 Score 5699 Marks
CPU Score 2603 Marks
Bear in mind this is on vista (300-400 points more in XP would be) Gona buy a cheap Sata drive from Ebay just for XP install :p: Or any1 know of major hotfix's for Vista performence to get close to XP performence i.e mass process deletion?
for testing you should make your sistem as light as possible..
i do my test on such setup..
Guys and girls I will have small surprise for all of you tonight!
Now I can only say that it will be something with letters R,C,D,H,F and numbers 9,0,7,2 .... :p:
All went well and I can show something now ...
This is overlay picture of what I'm playing with:
http://img86.imageshack.us/img86/8060/1000505eh6.jpg
And this is first result from it::D
http://img86.imageshack.us/img86/9753/3dm06cfcx1.jpg
According to ORB this is fastest AMD CF system on earth! (I know Phenom box is faster but we can't buy it for now :))
As you can see cards was on stock clocks for this test.
I also needed second PSU for CF coz my OCZ 600W didn't liked powering all my stuff :D !
The run you see here :rolleyes: reached 679W peek power according to my KillAWatt :up:
More to follow shortly...
very nice gear lightman. xmas come early at yours did it? :p:
will be nice to see what you can pull with that setup.
Lucky for some Xmas comes early :rofl: Nice score too i might add!!
Need some cable managment there :yepp: ...
Put down for Xmas list also... An Antec Quatro 850W or 1000W... comes with 2 x PCIE 8 pin so you can get more OC from you 2900PRO's!!
But also these puppies stable as :banana::banana::banana::banana:!!...
What were clocks on both GPU for this run? Ill tell you what ill update your score on the scorebord when you break 14K :rofl:
Im gona hold out till the Asus 790FX comes out.. but not first rev with SB600 i want SB700...!! Reason be the SB600 Sata ports have issues with Blu/HD Dvds drives... with a 24'' 1080P screen this is a feature that cant be sacrificed... so i will have to make do with Crosshair then OC the :banana::banana::banana::banana: outta my 6400 :D
Thanks! Unfortunately second card is for my friend setup....
And TBH it sucks!! Only 1.1V vgpu and 770MHz core stable :shakes:
Still I will try my best ...
It was nice and clean with cables before I decided to put second HD2900 :p:
My X-Mas will be very pure in terms of computer hardware coz I'm buying freaking HOUSE! To get some decent hardware I will need additional job ;) !
Previous run was at stock XT clocks, but this is at 770/980 which is max stable core for weaker (new) card. BTW weaker card is Sapphire...
http://img507.imageshack.us/img507/1...f770980uy6.jpg
As you can see I will have hard fight for this update on score board but you can start preparing it for me now :D .
PS. SB700 should be on market around Q1/08 so still couple of moths of waiting ...
wrong thread : (
please get the lastest driver from nvidia.com which will boost the scores.
I bought my Crosshair for £130 delivered new so i guess Q1 2008 should be fine to get good use out of it then flog on ebay for £80++
Cant you get any more Mhz from you CPU?, you had 250x14 benchable on your last mobo!... more mhz would see you past 14K for sure!! Tell you mate he should of bought His Edition as they allways use in top end cards the best binned cores :D
With two cards seems performence boost is mostly in HDR1 sector! others not improved vastly..
In crossfire what temps you get loaded?, for highest temps i find Age of Empires 3 does the best 5-10C hotter then any thing else ive used!! 2 hour game im seeing 85C with one card is very well ventilated case :yepp:
Because Sapphire is only 1.1vgpu I'm seeing around 75C @770MHz core, but obviously top card is hotter by 5-10C!
I will push CPU today, it was stable @3570Mhz 1.525V for SuperPi and general use. I just need a bit more time to tweak it properly...
PS. at around 2AM today, before I went to bed, I did 13992 run 06 and just to let you know that 3DM03 scored 61K+... Will upload SS later today... :)
UPDATE:
I DID IT!!!
http://img155.imageshack.us/img155/9...f780980wa3.jpg
http://service.futuremark.com/compare?3dm06=3490119
It took me couple of hours of tweaking but finally I achieved my goal! My mem won't do more than 1020MHz stable and CPU 3520MHz looks like max stable on AIR.... No matter what I do, it won't go through 3DMark CPU test over 3520MHz (but will do SuperPI and other things) ..... :shakes:
Now please update first page :p:
:clap: , nice to see Amd is still live and kicking...
Ive got same thing with my 6400X2 can bench 3500mhz@ 14x250 with not much over stock voltage but as soon go higher i.e 3570 gets unstable/unbenchable... but this is on Crosshair mobo maby if i had your mobo would be able to get it stable?
If only you had 2x His 2900XT 1Gb Editions are your disposile :p:
Here's my little update, single 8800GTS @ 630/1960
http://img.photobucket.com/albums/v1...pdog/11022.jpg
compare link
http://service.futuremark.com/compare?3dm06=3501365
It's cooled by a Zalman 9500
stepping is CCB8F 0720RPMW and thanks for the hint
I'll give it a go
