Does anyone know could an XL-ATX fit in my PC-343?
No, it only has a regular 7 slot MB tray/back panel.
Per EVGA's FAQ answer about this, only the cases they list can fit the 4-way, plus additionally now, almost all of the MM cases have an option for a 10-slot MB tray that can fit the 4-way
Damn so im stuck with E-ATX meaning i have to get an E760 single CPU board and without a nf200 chip so no x16 tri-SLI when its fully utilised by the GPUs,
No W555 dual CPU either :(
Although, it might be possible to mod it...., lift the mobo tray up a bit, aghh i dont want to have to buy a whole new case, i was looking at MM in the first place i should have just bought one :/
So I bought an E760 and an EK X58 full cover block,
I saw these things on koolance website and they look really handy:
http://www.koolance.com/water-coolin...product_id=787
http://www.koolance.com/water-coolin...product_id=786
Has anyone had any experience with these things, Any restriction problems?
My EK res, fluid, cpu block and compression fittings arrived... i love packages ^^,
