Do it there's gotta be something wrong in that reading:shrug:
I'm using 0404 for my P5K-Dlx and from what I know that 0501 beta and 0404 official doesn't have much variation in terms of overclock-ability and temp wise, it'll only be a matter of 1~2 degrees of difference.
So I don't think it's your BIOS becouse actually our batch is quite a good overclocker that goes up to 3.2ghz at only 1.32v loaded but temp must not be reading correctly. You should probably check your watercooled setup.
OR
Maybe I should get some balls and rip open my Q6600 G0 box in knowing that we've the exact same batch L723A765 and just to prove that something else is wrong for the high temp and not the CPU itself :p:
Get some balls and rip open your Q6600 G0 box:yepp:.... or, send it to me to test:p:
I'm going to wait a few weeks for the shops to get rid of B3 and the prices to settle a little before I buy one but damnnnn I was thinking about E6850 instead but now I just want one of these soooo bad. 3Ghz Stock volts and I'd be a happy guy.
2 orthos per core? thats insane, but 85C isnt right..... get a fuzion now.
EDIT: use coretemp, not everest!!!!!
I will have to replace my storm, I imagine it just isn't up to snuff.
IS THIS XS?OR A PLACE FOR THE WEAK:rofl: .:D
Cmon Tiramisu, we are all anxiously waiting...
HAHAHAHAHAHAHAAH ROFL LMFAO
the replies
OK...we'll see ;)
Open the box and stop wasting time with double posting:clap:
Dazog are the coretemp VID and Tjunction right???
http://img512.imageshack.us/img512/626/coretempfk1.png
Try coretemp 0.94 and see if temps are the same
coretemp 0.94 download >> http://www.filehost.gr/download.php?...261a22c33c27e6
regards
Put the chip in and see for yourselfe.:up:
can any one tell me why i am get deff temp
http://www.ruffrd.com/rdpic/wcpc/upqpc.JPG
Dazog, try to remove the waterblock..
to check the thermal greасе imprint, clean it up and install the block again.
Is the pressure to the CPU enough?
It seems like contact problem to me.. :shrug:
Here's mine :
http://s30.photobucket.com/albums/c3...600G0-3000.jpg
G0, same batch as XtremeTiramisu :)
a fellow storm user has seen the light!http://www.xtremesystems.org/forums/...ght=storm+quad
Xilikon, what is your max OC so far?
