My P5K dlx is oof by this same amount. I'm starting to think it is by design.
it seems a lot of boards experience that!...my Abit QuadGT has about .03 to .05 difference between bios and what is actual vcore for idle conditions....the variation is because my idle vcore throttles between 1.5 and 1.52v..i have 1.55 set in the bios.
Very interested in the IP35 Pro or Asus P35k Delux. Never had an Abit mobo before, how is their support? Sounds like they're slow with Bios updates.
the QuadGT team were very slow getting bios updates out...i hope they do not duplicate that same experience...probably a different team watching over the IP35.
I received this motherboard today, I begin the tests tomorrow :D
http://users.skynet.be/fb331210/ip351.jpg
http://users.skynet.be/fb331210/ip354.jpg
@CornerJack : ruh it I ll waiting your result... My board come to late to my Place
You who have the board, can you please post what kind of clockgenerator your board has? (The big IC just below the upper most PCI-E 16X port)
Some moment OC from CROTALE :up: :up: live in COMPUTEX TAIPE he can FSB 610 :eek: :eek: with ABIT IP35Pro :
http://valid.x86-secret.com/show_oc?id=207608
http://img.techpowerup.org/070613/610.gif
Kinda slow for 4.2GHz isn't it? All because of 2MB cache?
@sofarfrome : Sure !!! but he just testing on high FSB on the Board.....
arrived today with team xtreem pc9200
E6600 stock cooler
http://img511.imageshack.us/img511/508/shot0003wn9.jpg
tonight on phase :)
4mb's of L2 makes a difference as well. if you check the bearlake thread after benching 499 vs 500. there is a forced strap change also affecting his superpi 1m.
http://www.xtremesystems.org/forums/...1&postcount=18
even though a different mobo in that thread i bet its doing it on the IP35's, to bad we cant force straps.
first results with phase
http://i198.photobucket.com/albums/a...t/Shot0005.jpg
Isn't it a bit slow ??
It should be low 11 ...
Compared to QuadGT :
http://img106.imageshack.us/img106/871/99695686kt3.jpg
i was told it was also memory...you can loosen timings and the time will be come higher to compute...presumably, the program data is being stored in system memory as it is computing.
On crotales run, memory was set loose as he was shooting for max FSB and testing stability each step with Pi.
With Phase Change...
Doom st how about my Banana!
