Sorry but I think you are a little confused. The blocks never went near a “scullery machine” as you put it.:confused:
I cleaned the blocks in a glass bowl using de-ionised water; they were only put on the stainless steel drainer to dry. I used a hairdryer to get rid of all the moisture that was left on them before they were put back together. I then put them in to sealed bags until they were needed.
