amazing work Edie!
amazing work Edie!
Thank you all for the compliments.
Some more file work to do.
This time I do not using the iron with the file job.
http://www.ediejo.nl/Foto/ELL2/121.JPG
That aluminum from AC-Ryan is very good to handle.
http://www.ediejo.nl/Foto/ELL2/122.JPG
First part done.
http://www.ediejo.nl/Foto/ELL2/123.JPG
But enough to do.
http://www.ediejo.nl/Foto/ELL2/124.JPG
http://www.ediejo.nl/Foto/ELL2/125.JPG
I like t.
http://www.ediejo.nl/Foto/ELL2/126.JPG
At last the long small peace.
http://www.ediejo.nl/Foto/ELL2/128.JPG
http://www.ediejo.nl/Foto/ELL2/129.JPG
http://www.ediejo.nl/Foto/ELL2/130.JPG
http://www.ediejo.nl/Foto/ELL2/131.JPG
http://www.ediejo.nl/Foto/ELL2/132.JPG
http://www.ediejo.nl/Foto/ELL2/133.JPG
Sanding and polishing is for tomorrow.
http://www.ediejo.nl/Foto/ELL2/134.JPG
http://www.ediejo.nl/Foto/ELL2/135.JPG
See you soon.
Today some sanding and polishing to do.
Starting with dry sanding.
http://www.ediejo.nl/Foto/ELL2/136.JPG
And ready with dry sanding.
http://www.ediejo.nl/Foto/ELL2/137.JPG
Continue with wet sanding.
http://www.ediejo.nl/Foto/ELL2/138.JPG
Than polishing.
http://www.ediejo.nl/Foto/ELL2/139.JPG
Almost ready, but it’s too late to continue. Tomorrow I must work early.
http://www.ediejo.nl/Foto/ELL2/140.JPG
Here you can see the difference between the two parts.
http://www.ediejo.nl/Foto/ELL2/141.JPG
Here even better.
http://www.ediejo.nl/Foto/ELL2/142.JPG
But that’s for tomorrow.
http://www.ediejo.nl/Foto/ELL2/143.JPG
http://www.ediejo.nl/Foto/ELL2/144.JPG
See you soon.
It's gonna look so good once all lit up with that polished aluminum and the green plexi... :eek:
Finishing the polishing work at the back side, that’s for next week.
Today I start with the front. First thing is taking out the mesh part for a moment.. Sorry Lian Li.
Drill a hole.
http://www.ediejo.nl/Foto/ELL2/145.JPG
And then with the jig saw.
http://www.ediejo.nl/Foto/ELL2/146.JPG
Don’t look good.
http://www.ediejo.nl/Foto/ELL2/147.JPG
Take the file. (again)
http://www.ediejo.nl/Foto/ELL2/148.JPG
It’s not 100% straight (right corner at the top)
http://www.ediejo.nl/Foto/ELL2/149.JPG
But that’s for later.
http://www.ediejo.nl/Foto/ELL2/150.JPG
http://www.ediejo.nl/Foto/ELL2/151.JPG
http://www.ediejo.nl/Foto/ELL2/152.JPG
This is the beginning from the front there will come more plexi inside and some mesh. The color black will also disappear.
But that’s for next week this weekend I go to Zandvoort A1 GP.:rocker:
Have a nice weekend all and see you next week. ;)
God damit this is some awesome modding there!
Another great mod, as usual. Great goings Ed :)
@Patriote, thanks.
@TRG, I hope I can beat the first one. ;)
And continue with the front panel. It starts to looks boring. Again file work to do.
http://www.ediejo.nl/Foto/ELL2/153.JPG
http://www.ediejo.nl/Foto/ELL2/154.JPG
Between the file job. I have some time to drill.
http://www.ediejo.nl/Foto/ELL2/155.JPG
And file it again.
http://www.ediejo.nl/Foto/ELL2/156.JPG
Only the sanding part to do.
http://www.ediejo.nl/Foto/ELL2/157.JPG
http://www.ediejo.nl/Foto/ELL2/158.JPG
http://www.ediejo.nl/Foto/ELL2/159.JPG
There is also some plexi behind the holes from the buttons. Now you think maybe why?
http://www.ediejo.nl/Foto/ELL2/160.JPG
These are really nice buttons. Because they have an edge on the bottom.
http://www.ediejo.nl/Foto/ELL2/161.JPG
Now you can see the plexi. And the buttons are working well.
http://www.ediejo.nl/Foto/ELL2/162.JPG
I put some light behind it to see the effect.
http://www.ediejo.nl/Foto/ELL2/163.JPG
http://www.ediejo.nl/Foto/ELL2/164.JPG
http://www.ediejo.nl/Foto/ELL2/165.JPG
See you soon.
Looking brilliant. There a great green glow of it too.
@cian1500ww, thanks
And continue with the front. Make a copy from the first part.
http://www.ediejo.nl/Foto/ELL2/166.JPG
And that one will come here. On the case.
http://www.ediejo.nl/Foto/ELL2/167.JPG
Marking the holes for sawing and drilling.
http://www.ediejo.nl/Foto/ELL2/168.JPG
And the saw job is done.
http://www.ediejo.nl/Foto/ELL2/169.JPG
On the case.
http://www.ediejo.nl/Foto/ELL2/170.JPG
Still some work to do.
http://www.ediejo.nl/Foto/ELL2/171.JPG
This time complete by hand.
http://www.ediejo.nl/Foto/ELL2/172.JPG
That’s fit.
http://www.ediejo.nl/Foto/ELL2/173.JPG
http://www.ediejo.nl/Foto/ELL2/174.JPG
http://www.ediejo.nl/Foto/ELL2/175.JPG
http://www.ediejo.nl/Foto/ELL2/176.JPG
Maybe I use this radgrill.
http://www.ediejo.nl/Foto/ELL2/178.JPG
http://www.ediejo.nl/Foto/ELL2/179.JPG
http://www.ediejo.nl/Foto/ELL2/180.JPG
See you soon.
You're brilliant at the filing, hard to get good square and even edges. Well done !
@cain1500ww, thanks for the compliment. ;)
Very nice :D.....looks awesome ^^
This morning I visit Point of View for a cup of coffee. No cookie at the coffee this time, but a nice suitcase.
http://www.ediejo.nl/Foto/ELL2/182.JPG
Some people will remember it from the Carbon Li.
1100Watt straight power. I love this one. The cables are no problem I go for quality. ;)
http://www.ediejo.nl/Foto/ELL2/183.JPG
Only the Point of View edition this time.. Tagan make good powersuplys.. I think it’s a good decision from Point of View to cooperate with Tagan.
http://www.ediejo.nl/Foto/ELL2/184.JPG
http://www.ediejo.nl/Foto/ELL2/185.JPG
No mod update this time. I was too late at home.
great work so far!
@illidan, thanks for the compliment.
And continue with the front. I make some plexi to mount the 2 reservoirs.
http://www.ediejo.nl/Foto/ELL2/186.JPG
I need the edges from the original front. So I can place the reservoirs exactly in the center.
http://www.ediejo.nl/Foto/ELL2/187.JPG
I use the standard mounting plates only for drawing.
http://www.ediejo.nl/Foto/ELL2/188.JPG
http://www.ediejo.nl/Foto/ELL2/189.JPG
Dan saw the plexi.
http://www.ediejo.nl/Foto/ELL2/190.JPG
http://www.ediejo.nl/Foto/ELL2/191.JPG
http://www.ediejo.nl/Foto/ELL2/192.JPG
Filing and sanding.
http://www.ediejo.nl/Foto/ELL2/193.JPG
http://www.ediejo.nl/Foto/ELL2/194.JPG
That’s fit well.
http://www.ediejo.nl/Foto/ELL2/195.JPG
http://www.ediejo.nl/Foto/ELL2/196.JPG
http://www.ediejo.nl/Foto/ELL2/197.JPG
http://www.ediejo.nl/Foto/ELL2/198.JPG
Almost the same as the plexi from the front. But this is to hide the plexi for a part.
http://www.ediejo.nl/Foto/ELL2/199.JPG
Again filing.
http://www.ediejo.nl/Foto/ELL2/200.JPG
Also the small holes.
http://www.ediejo.nl/Foto/ELL2/201.JPG
http://www.ediejo.nl/Foto/ELL2/202.JPG
The black anodized will be removed. And it will be polishing.
http://www.ediejo.nl/Foto/ELL2/203.JPG
http://www.ediejo.nl/Foto/ELL2/204.JPG
See you soon.
This is absolutely amazing. The attention to detail is fabulous!
this is gonna be awesome...I wish i had a nice workshop like your with all them tool's....
I haven't done any modding before...I want to cut into my v2000 side panels and place in modder's mesh is a jigsaw ok for the that? any tips i've never used a jigsaw before.
cheers mate
Absolutely love it man... Amazing work!
But why does nobody ask about the DVD. There is no place at the front for that. :shocked:
