not to sound rude or anything, but do you even know what those numbers mean specifically in relation to performance?
Hmm something tells me that these are the same ram as I have.. They used to clock _really_ bad, but since I changed to the yellow slots on my mobo and adding water to the northbridge - they absolutely fly!
http://2200kbhn.dk/temp/505MHz-mem.jpg
This is with 2.4V I'll try to lower it a bit today, and I'll try 4-4-4 to see if I can go higher. The only problem right now is the motherboard, it is _really_ strange.. 8x472 is 100% stable, but 394x9 is far from stable..
EDIT: I now run it at 2.1V and looser timings
This is the highest I have it by now - maybe there is a tad more to get from it.
http://valid.x86-secret.com/show_oc.php?id=229321
EDIT2: I have found the limit at 2.1V now..
http://psaforum.dk/imageupload/?id=436&db=.jpg
Unfortunately I forgot to get the vcpuid validated :( I'll do that later.
Nice results TB.
These chips are in fact Elpida and don't have a tendency to melt with higher voltages! Also the kit is 159.99 at Newegg without a rebate: http://www.newegg.com/Product/Produc...bXLC%2bCAS%2b3
Thats pretty good hey, 525.5 MHz 4-4-3-8 at 2.1v is comparable to good D9's at the same voltage :up: I'd be interested to know what their 100% orthos/game stable timings are at 2.1v :)
thats about right m8 for the temps, I see the same here during my testsQuote:
Originally Posted by TheOriginalTB;
Mine shoots straight up from 35*C to 55*C on coretemp when starting orthos, then maxes out at 57/58*C. I think its normal behaviour, i have good HS to cpu contact and am using AS5.
I see a fair few people getting around 60 - 65*C on water. Whats you vcore, around 1.48v?
Ok, I'm back again, now it seems like I have sorted the heat issues. And I have vdroop modded my P5N-E SLI.
I'm at 556MHz ram now, 2.1V CAS 5-4-4-15-2T I'll try to get a new screenshot with 525 CAS 4-4-3-8-2T later.
Screenshot will follow.
Sounds good.
Ok, seems like 570MHz CAS 5-4-4 is max at 2.1V - or it is my CPU holding me back. (or more likely the crappy mobo..)
http://psaforum.dk/imageupload/?rsz=1&id=515&db=.jpg
at 572 it's not dual Prime 32M stable, but 1M is just fine ;)
