Maybe you could pm some people?
no pics, come on you know XS better than that, and we should know better than to steal. i just want to see how it turned out after those preliminary drawings you sent me cus it seemed like a cool idea :D or at least pm me them to see cus im excited to see it.
I would love to see this as well. I used to own an external box and absolutely loved it. Regret selling it to this day. The thing I love about external is you can get any case you want. And I'm a big time case whore. Would love to see you get this up and running.
Hey P8NTSLINGER676 & SOCCERSWIM8, I want to thank you guys for all your interest since I began this idea. P8NTSLINGER676, thank you for offering to help with the case at the beginning, but you know how ideas go, they change every minute, and it would have been to much of a hassle to keep sending you different case ideas, and i'm sure you understand what I mean. Here are 99% complete pictures, the only thing left to do is hose clamp everything.
Imageshack seems to be down at the moment, so I cant show them to you all yet I guess.
Let me explain how you power this waterbox. The back of the unit has 2 MOLEX connections, and 1 switch (I'll explain the switch later) I provide you (customer) 2 molex cables (made by yours truly:p: ) and a PCI pass thru bracket. Simply install the PCI pass thru bracket into your PC, and then connect my 2 molex cables from the PCI pass thru bracket, to the 2 connections in the back of my water box. DONE! With those 2 connections made, your powering the pump, fan controller and the 2 4" CCFL's;) . The switch on the back of the unit controls the "ON or OFF" function of the lights. The only MOD you (the customer) will have to do is drill "2" 1 inch holes to your case as I ran 1/2" tubing for my waterbox so I could get every last drop of performance from it. People say use 7'16ths tubing as it doesnt hurt performance, but even If I did use 7/16's line, the tubing still gets squashed pretty bad going through the PCI expansion area, so I stuck with true 1/2inch tubing for everything. I provide the 2 grommets so no worry there:) . Also there will be an included allen key for the drain valve (and it works great, I've filled and flushed this system 3 times for testing purposes)
All the wiring inside the case is very neat and for the most part sleeved. The inside of this case has neon blue CCFL's, but different colors are always available. Taking the cover off the water box is a breeze, so filling the unit is very easy with the top of the RES being right in front of you. I personally kept the cover off till all the bleeding was done, and I find having the RAD on its side and slightly off level, made bleeding this unit MUCH EASIER then my personal PC which has pretty much the same stuff, but my RAD is on top of my case. I love my "thumb screw" usage for the RAD on the outside of the box, really breaks things up a little bit. Im using YATE LOON fans, so it is VERY quiet to say the least. Pricing is still something I have to go over, but will have the answer later today. I still have to make 1 more external power cable for this unit, but I cant right now as im out of molex pins:mad: . I should have those later next week however. As far as the paint color for the case, This type of paint (Hammer finish) comes in i think 6 different colors: BLACK, GREY, GREEN, AND I CANT REMEMBER THE REST, just wanted to let you all know, as this mock up unit is black, I just didnt want you all to think this was the only color. I also ship/use D-Tek fuzion blocks with these:D Let me see if imageshack is up yet...........?????
http://img462.imageshack.us/my.php?i...scf0830po5.jpg
http://img462.imageshack.us/my.php?i...scf0831zk5.jpg
http://img354.imageshack.us/my.php?i...scf0832cv2.jpg
http://img112.imageshack.us/my.php?i...scf0833ml0.jpg
Pleases feel free to PM me, and if you want to talk I'll shoot you my phone number:) Im going to take one more picture to with the whole bundle of every thing you will receive with my water box, but i'll have to do it later, as I need to leave for a moment.
VERY impressive-looking! :D
BTW, I have an idea for that PCI tubing pass-through which would allow for the use of 1/2" tubing without reducing the crossectional area of the flow path (and it would work without case modification). If I have a chance this weekend, I'll take a shot at modeling it for you.
newls1,
Very nice work indeed!
Here is a pic of "ALMOST" the complete package. The only thing it is missing is a second molex cable I believe.
http://img389.imageshack.us/my.php?i...scf0834ac8.jpg
Sweet idea and nice look of it as well.
1 question, potential for swapping out parts? Different pump/res etc?
OK, I'll work on that in about 20 minutes or so, I have to get a few things done first:)
How are temps? these should be as good as the kit inside them really, and not like the koolance exos etc.. in other words, the kit in this external housing should be as good as that kit inside the pc.
How about altering fan speed? not possible?
i had an idea of like a water level monitor to go in the res aswell, like if it goes below a certain level it could beep so you know it needs a top up or whatever.. not really essential though as you can see the res through the window anyway.
Seems really good, but wouldnt having a high end gpu & cpu all in one loop on a triple thermochill rad make temps go a little high?, especially if you are overclocking.. Shame 2 rads cant fit in there.
looks roomy enough for other types of res, like the multioption...
some sort of handle would also be nice...
It seems as though my thread got locked (the other thread i've made) for selling outside the classifieds. What do you all think I should do?
re post in the right thread next time.
at least the one here is still good, this is basically a watercooling idea.
don't mention pricing in this thread, do it via pms and emails, or
in the selling thread.
*i think in a reply above post you mentioned a price, better edit that said post.
hmm also nice case for and external pump rad res you got there.
OK......For pictures and buying of the product, please click this link for now on. It is my understanding that I broke a rule here (I apologize for that too) and started a thread in the classifieds section here (http://www.xtremesystems.org/forums/...=1#post2115921)
Thank you, and 1 more note to everyone...... I bought some new case cover screws to help in appearance, will see how they look in about 20 minutes.
Here is the link for everyone http://www.xtremesystems.org/forums/...d.php?t=139984
Not much going on in that section & to be honest with you all I feel like i'm in DETENTION, but I guess this is the only section for this to be in?
The screws do look a lot better but my suggestion would be to paint the expanded metal grill black.
