sorry, dimensions are in centimeters, but i was saying that the heigth is considered with the plastic feet.
about HE 120.3 can't find datasheet on thermochill site..someone give me dimensions?
not sure maybe at http://www.over-clock.com/ivb/index....ab823c0d10628e and http://www.thermochill.com/guides.php ?
That looks really awesome, great idea and the green came out really nice. I see the DVS skate more stickers on the monitor, someone skateboards.
that's a REALLY nice bench station !
me want one :)
YGPM
my sister;)...
x Eva2000, i take a look of the he120.3, it's a must to use the fan shrud?
couse if you use the fan shorud holes are the same of the PA, but the sum of thickness will be more considering the fan shorud, so maybe need a different support instead of the PA120.3 model.
wow nice paint job
I have fan scrout on mine 2.
My Girlfreind gave me a LD compressor cooler in selebration of our 3 years together. And now I need the benchtable 2.
But like eva2000 I buy Qulity ONLY :D
That is why we have thermochill HE120.3 and PE :D
Dimas made a Bracket for mounting it, I think it will work, thoug I would have liked a native support for it without brackets :(
http://www.pc-phasechange.it/fotoupz...e/IMG_7522.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7524.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7525.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7526.jpg
waiting for the "special support" that will hold the long screw;)
they have holes on bot sides of the rad m8 :D
http://www.thermochill.com/images/products/pa1203.jpg
Im QUITE sure it gase the same holes on both sides.
Dimas, that is absolutely awesome. :toast:
ok..finaly..they have the same fans holes, but HE is shorter than PA(416mm vs 430mm), and PA is a bit more thick than HE(64mm vs 56mm)
so HE on my table will have the same holes and supports;)
i would have do a blue bench table, cause you are italian, and italy is blue, blue sky, blue eyes girls, blues squadra azura, mediteranean sea is blue etc...
:D
i'm going to take some black glossy and grey glossy, today..posting photos later;)
Dimas thats so bloody cool!!
Do i see 2 80mm fan mounts for RAM & GFX cooling?
1 120mm rear exhuast fan?
Big black frame that goes over the top, with the all thread rod, thats for holiding a LN2 tube done with the rod going inside the tube?
Love the carry handle.
This one is pure bench table as i don't see any HD, PSU, Optical drive mounts.
I'd love a version of this white and black one with the drive mounts too for it.
Be perfect fro my Penryn then.
Oh is there enough space under the mobo for Phase/casacde/ln2 BACK PLATES?
yes, support are for 80x80 fans, and one 120x120 to move air in the socket zone...
yes, the black Arch is for hold pots or a waterblock without using clips,there's still left a "special bolt" for the long screw;)
about back plates, there're 25mm of space...
and about drives and hard disk, you can take the other bench desk that stay down, the 2 parts can be screwed together via 4 screw+bolts...
here they are final revision finally explained:D
EASY MODEL
http://www.pc-phasechange.it/fotoupz...e/IMG_7548.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7549.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7550.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7551.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7553.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7555.jpg
EASY+HARD
http://www.pc-phasechange.it/fotoupz...e/IMG_7556.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7557.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7558.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7559.jpg
HARD MODEL
http://www.pc-phasechange.it/fotoupz...e/IMG_7560.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7561.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7562.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7564.jpg
lot of colors incoming...i've to find time to make photos..
please show us the bench table with a complete list of hardware installed on it
grey version
http://www.pc-phasechange.it/fotoupz...e/IMG_7590.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7591.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7592.jpg
and white with parts on
http://www.pc-phasechange.it/fotoupz...e/IMG_7595.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7596.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7597.jpg
http://www.pc-phasechange.it/fotoupz...e/IMG_7598.jpg
regards
