Sweet! :)
When i'll have the time i'll test mine higher.
Sweet! :)
Does this also apply to the ddr2-800 version of these chips? Even though the specs say to run them at 4-4-3-8 @ 2.2v...if i go anything higher than 2.1v i get blue screen and reboot b4 it even loads into windows. Doesn't matter what timings. This is with the abit aw9d-max board. Bad or incompatible ram?
We are talking about the DDR2-800 version. And yeah your problem can be due to bad ram or motherboard incompatibility. You'll just have to check yourself. Try the ram on another board if you can, or RMA the ones you have and see if you get the same problem with the replacement they send you.
lol, dunno why i thought u guys were taliking about the T1000...well i ran memtest on them last night in dual channel and got a TON of errors in tests 2 through 8. Gonna go home and try 1 stick at a time and see what i get...im pretty sure either 1 or both sticks are faulty.
ok, so i was testing out the ram
I put my system at FSB 356, 1.4vcpu, 2.1vdimm, 1.65mch w/ 1:1 ratio @ 4-4-3-8. This put the ram at 712mhz. It passed dual SPi test.
I then just changed the ratio to 4:5, which put that ram at about 890mhz. It did not pass the dual SPi test. I even tried it at relaxed timings of 4-4-4-10, but still failed.
I would like to increase the voltage to these modules, but if i go anything over 2.1, i get blue screen and it does not boot into windows. I just ordered the team group cas4 ddr2 800 modules, hopefully i'll have more luck w/ those :)
btw, according to cpuz, mine are week 41 w/ blue head spreaders
I have played with a few configurations of the supertalent ram modules manufactured august 17 2006 blue T800UX2GC4 .
I find them incredible and very solid .
ddr2 800 stock 1:1
http://img522.imageshack.us/img522/2...3530ki0.th.jpg
ddr2 1000
http://img105.imageshack.us/img105/9...2327jg7.th.jpg
ddr2 1066
http://img213.imageshack.us/img213/6...2926eu4.th.jpg
ddr2 1100
http://img522.imageshack.us/img522/7...3258xc8.th.jpg
ddr2 1200
http://img209.imageshack.us/img209/5...2528ks7.th.jpg
Week 17 is an early week. They are probably GMH.
Or GKX maybe?
I didn't know the SuperTalents had GKX.. if so, the man is lucky!
I'm still waiting for my GMH Crucial's to arrive... 10th anni. Hopefully they clock nicely.
if we knew that these cheapo sticks back in the day had GKX... we'd bought them all up!!! :)
Some of us didn't know it back then, but had luck on their side.... :)Quote:
Originally Posted by shimmishim
May the luck be with you!
Είσαι και τυχερός:D
I bought my ram after a little chatter on the forums got my attention.
also one good recomendation from a new found friend.
I'm not complaining at all :D
I only wish that I would have ordered 2 more gig.
Does this review give any info on how it is overclocking?
Yeah, i think that's pretty much it. That's the o/c potential of the latest batches...:mad:
Have enybody bought this memory recently?
I recived 2x1Gb kit week 45 but one memory stick was faulty so i send it back, now i am waiting for the new kit.
Meybe they use D9gmh again
That would be nice but i don't think it will happen anytime soon...
McPhisto
you have 6400C5 ? Are they Promos/Elpida? Here in Bulgaria we have C5 model too, is it good?
As far as i've figured out you have to take a look at the manufacturing date. The earlier date the better the RAM.
Mine can do easy DDR2-1000 @ 4/4/4 @ 2.25-2.3V (week 31) but i didn't take off the heatspreader to have a look, so i don't know for sure what IC's are used.
Your ram isn't as old as u think. Mine is week 19 and have the same behaviour with yours (GKX propably). So consider yourself lucky... :)Quote:
Originally Posted by McPhisto
Do they have silver heatspreaders?
No, i got the one with the blue heatspreader.Quote:
Originally Posted by JoeBar
Wel,i put these back into my sys after 2 months and they work again :stick: ...??? WTF??Quote:
Originally Posted by thebeast
Blue heatspreaders and week 31's..anyone sure on the chips yet?
i have a week 31... not sure on the module but i'm guessing d9gmh... i can run 475 1:1 @ 4-4-4-12 with 2.25 volts.
I have week 1 silver heat spreaders! Bought them from Tulatin, unfortunately, my DS3 throws fits over 445fsb with them :( I think it's about time for a P5B-D!Quote:
I haven't read many success stories with this ram and DSx boards.Quote:
Originally Posted by Lil Big Mec
With P5B-Del, trust me, it's a safe bet... :)
