Originally Posted by tjelaw
Well... Ive been playing around with mine, and it not what I expected.
The OC-ing performance is okay so far, 370x10 with 6700 ES, fsb:mem 1:1.
But nothing my P5W-DH couldnt do. Im own a rev. 503 btw
My findings:
- vdroop is not that bad, but not as excellent as tim0r says. (note that using the advanced power slope feature helps!)
- I find the overclocking feature pretty frustrating and disappointing. If you set a too high setting, and it wont boot, you will have to clear/config the bios manually by turning of power and switching jumpers EVERY TIME. As where the P5W just automatically uses safe settings when boot or post fails.
This is very very very very f:banana:ing annoying, especially since OC-ing in windows is not yet possible, because of the new PLL IC.
I can see myself trying to find the best vcore-vMCH-fsb ratio and having to switch jumpers 50 times every evening. And its not placed in a easily reachable place!
- The BIOS freezes very often while adjusting settings. ctrl-alt-del helps to reboot. But it seems very buggy. Having had to try 5 times to change vcore from 1.55 to 1.6. NOTE: this also happends with perfectly stable stock/default settings. I already updated to the latest bios
- CPU multi is NOT adjustable, at least it isnt for me. The option is shown in bios, but isnt selectable.
New bios plz?
More to come
