I was wrong, I tried it and it wouldn't boot. To fix: put a good stick in and boot... Flash back to original spd......
I'm getting the no memory modules found, incompatible smbus driver - it's under Vista.
Is there any chipset driver I can install to fix this or am I SOL?
I need to flash some chips :(
It's an intel 845 chipset I'm trying to do it on.
no ddr2 for 845
Does these work when Using a X38 as a motherboard?
Yes, it works on x38 :)
I see you have maximus and it works on it no problems here :) Are you using latest 0.62 version?
0.55 doesn't appear to work on my MSI K9A2 Platinum (with a 6000+ Windsor F3)
it says "Could not start driver: This diver has been blocked from loading"
I'm using XP x64 with SP2
*edit*
0.62 works on it.
Is the ati express 200 for intel supported.Do you need the wpcredit id #?:up:
In my search, I found this site and it goes over the basics of SPDTool:
http://forums.overclockers.com.au/sh...d.php?t=562506
I had kind of worked through SPDTool basics on my own going step by step through the hex table and was merely trying to match two sets of similarly timed DDR to run at 400mhz on an MSI board I like. But that page seemed to cover the essentials.
BTW, thanks W1zzard for this excellent utility!!
RHH
someone have find the solution for use spdtool under ICH10R ??
wow this tool might save my day.
i have a corsair dimm reporting some strange spd info.
its form a set of "twin2x4096-8500c5df" modules
the jedec1 seems completely of.
part of cpu-z SPD info:
DIMM #3
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number CM2X2048-8500C5D
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP yes (1 profiles)
XMP no
Timings table
Frequency (MHz) 270 400
CAS# 4.0 5.0
RAS# to CAS# delay 4 5
RAS# Precharge 4 5
TRAS 13 18
TRC 16 23
EPP profile 1 (full)
Voltage level 2.100 Volts
Address Command Rate 2T
Cycle time 1.875 ns (533.3 MHz)
tCL 5.0 clocks
tRCD 5 clocks (9.25 ns)
tRP 5 clocks (9.25 ns)
tRAS 15 clocks (28.00 ns)
tRC 22 clocks (41.00 ns)
tWR 8 clocks (15.00 ns)
DIMM #4
General
Memory type DDR2
Size 2048 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
XMP no
Timings table
Frequency (MHz) 76 400
CAS# 4.0 5.0
RAS# to CAS# delay 1 5
RAS# Precharge 1 5
TRAS 4 18
TRC 5 23
tCL 5.0 clocks
Hello,
In my Gigabyte EP45T-DS3R no working...
Error in Start : ''No Memory modules found. Incompatible SMBus driver?''
I'm using Windows Vista Ultimate X64 SP1
I'm necessite flashing my kit memories DDR3...
Help for my question? Incompatible for my chipset?
Programa version 0.62...
SPD-Z for OCZ no working... Error: ''Could not start driver: This driver has been blocked from loading''
Help me, please
Tnks people
SPDTool does not support P45 chipset.
Yes,
Tnks people!
