Your DVM is reading high. Either send it out for calibration or get a new one.Quote:
Originally Posted by K404
Viper
Viper
OK. I bought a 2nd DMM, reads exactly the same as the other one. Dumped GPU BIOS into Nibitor and I get:
http://img242.imageshack.us/img242/3...voltagepl2.jpg
Waiting on kemist to tell me if hes modded the BIOS or pencil modded the card (which I dont think he has)
bump :) Any other GTS owners want to add info?
GTS owners could add their sotck idle and load voltages here. In my GTS those are 1.26V / 1.21V
Mine is 1.35V constant, un-modded.
I take it that a bios vmod isnt possible (at least currently) with the 8800 series?
If I wanted to use a fixed value resistor for my 8800gtx's to bring the GPU's up to 1.4v what value resistors should I purchase?
Depends on what your starting voltage and board is!
GTS owners. We need your stock idle/load gpu voltages. It's not so hard to measure those :D
1.343V idle, 1.352 load (DMM, measuring left hand point as shown in original post)Quote:
-> on an Asus P5B DH
(@SF3D, lol sorry)
Yes, I know that your GTS have different voltage :) Mostly that's the reason I'm asking this.
Someone else, please!
1.26V Idle, 1.24V load. Asus P5W DH, 8800 GTSQuote:
Originally Posted by SF3D
I have pair of Chaintech 8800GTS cards. Both without hardware vgpu mod, only Vmem pencil mod done. Vgpu is 1.27V in 2D and 1.23V in 3D (under load by ATITool's cube).
1.28 idle
1.26 load
Asus 8800gts
By the way my previous albatron had 1.0 ns ram o/c @ 2150 stable without mods,Asus instead has 1.2ns ~ 2050
Sorry...quick diversion... I noticed theres an SMC gone walkies from my card... PLease can someone help me out?
http://img261.imageshack.us/img261/3...lemarearx2.jpg
So the OVP is kicking in at aprox 1,45v? (core) Is there a way to beat the OVP?
Black screens are somehow related to temperature and/or over current protection. Just quessing..
Boblemagnifique was able to run 3D01 with 1,57V and 820MHz. GTS was cooled with single stage (?).
K404
That resistor could be some current sensing input. In primarion 3535 that resistor would be CAL_CUR_SEN pin.
Still missing that 3540 datasheet.
Would you please tell us which pin of the px3540 chip is the red point resistor connected to???
Good guess. Vcore PS shutdown on OVP will almost always occur idling at the windows desktop on cards the do not have split 2D/3D vcore...which the 8800GTX doesn't have. It is one Vcore fits all so the Vcore will be highest idling at the Windows DT as there will be no loaded Vcore droop (the 8800GTX has a TON of droop) which will take the Vcore down below the OVP setpoint when the card loads up.Quote:
If the Vcore PS shuts down loaded up in the benchmarks in will almost always be on OCP. I am not 100% sure but I think the Vcore PS, on the 8800GTX at least, has a temperature compensated OCP setpoint where the PS will shutdown on ever lower total GPU current draw as the die temp increases.
Viper
I have made picture where you can see that trace. (Post 60) That pin should be V_SEN pin.Quote:
Originally Posted by fatbird2046
I did the vmod to:
http://desertshooter.nl/vmod.jpg
http://desertshooter.nl/20093%20(small).jpg
That's nice..but how much does your GTS need to do 702? My GTs run fine with 1.25V load at that speed. Do you have black screen problem with higher voltage?
I will use better cooling next time I bench. (In january)
Merry Xmas and Happy New Year to all :toast2: :toast:
http://www.pt1t.net/8800GTS/2k1_GTS_...00_4800mhz.PNG
unmodded and stock cooling , Vgpu idle 1.32v / load 1.295v
XFX 8800 GTS
VGPU: 1.27 idle 1.23 load
VDDR: 1.85 the whole time.
Able to run 660/1050 with stock cooling, running 625/950 for 24/7 for now. I'll be putting it under water this weekend.
