I'm gonna look at the most logical explanation for this difference. First, how many days went by between test 1 and test 2? Was ANYTHING in the loop touched between first and second test? Was the CPU block remounted? Was tubing knocked? You see, if you even bump the tubing near the cpu block you could throw the block off and get different results - sounds crazy but true. I would bet that if you reran this test ON THE SAME DAY the results would be different. IDK why you have not done that - one test is meaningless without more tests to back it up.Quote:
Originally Posted by virtualrain
