Jup, that'll make waterramcooling even more worthwhile than it already is
OT: help me anders ff met de kennis te vinden op telenet ^^
ik vind zelfs nog geen overklok gedeelte op het eerste zicht
UPDATE:
I'm running Memtest86+ V1.65 now for about 1/2 hour at rated speed of the rams @ 1000MHz DDR and Cas 4-4-4-12 at 2.2Vdimm......It seems to go well without any mistakes till now!......Those ram modules are going to drive me nutts.....
Yesterday I tested them on another AW9D-MAX mobo cuz I though that it might be the Northbridge from the 3.4Vdimm but nothing.....Same thing.....
interesting... perhaps a one time fluke?
3.0v degraded D9GMG pretty quick for me, but it might have been the PCB as well. :confused2
hypro whats the max they can run 1:1 4-4-4-12 @ 2.2v / 2.3v ????
regards
I'll test that too.......Quote:
Originally Posted by mascaras
Factory defaults which is 1000MHz Cas 4-4-4-12 with 2.2Vdimm is OK......I reached up to 517MHz(1034MHz DDR) with Cas 4-4-4-12 and 2.2Volts error free.....
Maxed out at 563MHz(1126MHz DDR) with Cas 4-4-4-12 and 2.65Vdimm......error free....
I'll continue tomorrow...
that's weird.. with those results at 3-3-3, i was expecting a lot more from 4-4-4... like in the 600mhz range at 2.65v. i have a pair of D9GMH that does 3-3-3 at around 460-470mhz with 2.8v, but can do 600mhz stable with 4-4-3 at 2.65v :confused:Quote:
Originally Posted by hipro5
sounds like your kit just REALLY REALLY loves tight timings :toast: :D
thats because im with a problem with my teamgroup pc5300 , :
My P5B Run 510 FSB no problems with GSKILL hZ of a friend mine .
With my teamgroup can run DDR-1100 @2.29v with 4:5 dividor but 1:1 i cant boot more than 470Mhz no matter what multi:
470 x8 1:1 ---no boot
470 x7 1:1 ---- no boot
470 x6 1:1 -- no boot
467 x8 1:1 ---- boot
438 x8 4:5 ---- boot
you think its the ram that cant run more than 470mhz 1:1 '??
I am considering seel my RAM and buy this Celshok
regards
you've posted this information in like 10 threads now :eek:Quote:
personally, i think it's a mobo issue. the memory doesn't "know" what memory ratio it's running at.
yeh , because in starting going crazy with this :DQuote:
Originally Posted by ozzimark
And because no one can answer that , or teel me what the max ppl can do with teamgroup PC 5300 cl3-4-4-8 1:1 , maybe hypro can , dunno.
Problem cant be the mobo because with Gskill HZ i can run 510x7 1:1
this realy pissing me off , i bought this mobo because my CPU seams to be a lot of potential and with my old DS3 i was FSB limited at 460 , now i bought this P5B that run at least 510 FSB and im stuk again :(
anyway you have sure , and sory for the offtopic
regards
now where is that gorillokas LN2 pot and that cascade +gfx :D.
very nice setup hipro ;)
:D You just made them addicted to hi voltage with Your 3,47 trial....., so now they want to be fed with 4 volts............ :slapass:Quote:
BTW - did You try 1:1 maximum with 7.8us refresh mode??? I made some tests, 15.6 gives more bandwidth in Everest but 7.8 is faster in SuperPi.
Hmm maybe after a few days they wont be mad at you anymore and they will listen to 3.4 again! :)
hmm, already 4 guy`s @ http://www.xtremesystems.org/forums/...d.php?t=118076 bricked they`re aw9d max while flashing. Be carefull, it can happen with dos and the in windows flash
guys a shop near mu house have 2x1Gb celshok 6400 ddr800 -4-4-4-
anyone know if they are good???
they also have celshok 8000 cl4-4-4- and celshok 8000 cl5-5-5-5
regards
:D Go with the cellshock 8000 cl4-4-4-.........;)Quote:
The user (LASAC) just bought the 8000 4-4-4-12 few hours ago in that shop .
1st boot DDR1100 4-4-4-12 @ 2.45v in bios ( 2.40v real)
Mobo P5B deluxe + conreo E6600 :toast: :toast:
regards
:D Nice decision - this RAM really rocks:Quote:
http://img300.imageshack.us/img300/7...2m49719am0.jpg
:fact:
My pair of Cellshock 8000 444 will arrive in a few days but there is no way I am giving them 3.5V, not even 3.0V :D Sorry :D
3.5V is just :slobber: xtreme^2 :D
LASAC 2 round >>> 570mhz 4-4-4-12 @ 2.45 ( with P5B dlx vdrop 0.1v = ~2.35v)
:eek: :banana:
BTW: They were only in stock for 3 or 4 Hours in this shop :D
regards
EDIT : But enough talking and lets go with the pics :D :
fotos:
http://img170.imageshack.us/img170/4508/dsc01413wx7.jpg
http://img83.imageshack.us/img83/7314/dsc01414ag7.jpg
first tests of E6600 L629A
http://img180.imageshack.us/img180/7983/11140ski2.jpg
CellShock boot to win :
http://img215.imageshack.us/img215/2632/567yb6.jpg
Sandra 2007 SP1:
http://img216.imageshack.us/img216/1971/sandra2dp5.jpg
http://img207.imageshack.us/img207/3204/572dm4.jpg
ALL with 2.45v in bios ( vdrop = 2.35v real) --- 570mhz CAS 4 @ 2.35v , its amazing :D
then only for curiosity LASAC did some 3dmark bench with 7950GX2 , E6600 and Cellshock :
http://img214.imageshack.us/img214/5003/71797xj3.jpg
ORB: http://service.futuremark.com/compare?2k1=9061118
that was only the first tests , more to come from LASAC , but this is very , very , very great RAMs , they run a nice OC only with 2.35v , its realy good ;)
regards
ehhhe thanks m8!
looks like i need some vmem on this p5b dlx.
the problem is measuring point.
i read under 1v on it with multimeter lol.
lasac, i think it's time for you to change that sig.. :p
continue testing them... you know very well that fsb will be needed for 1:1 to continue testing that 6600
:eek: Oh nice - 4.5Ghz on water with an E6600.......:confused: - is that true???:eek:
It's an Vapo LS cooled cpu :)Quote:
Originally Posted by camouflage
:eek: Oh I see - what a bug, his SIG says "all watercooled"...... :stick:Quote:
Originally Posted by Helix
his SIG is not prime stable and therefore throws errors :D
