AMD publication # 32559, page 124
Dynamic Idle Cycle Counter Enable (DCC_EN)—Bit 5. When set to 1, indicates that each entry in
the page table dynamically adjusts the idle cycle limit based on Page Conflict/Page Miss (PC/PM) traffic.
Idle Cycle Limit (ILD_lmt)—Bits 8–6. Specifies the number of MemCLKs before forcibly closing (precharging) an open page. If DCC_EN (Function 2, Offset A0h) has a value of 0, the static counters are loaded with the ILD_lmt and decremented each clock. If DCC_EN (Function 2, Offset 94h) has a value of 1, the dynamic counters are loaded with the ILD_lmt and modified as follows:
Increment—When a Page Miss (PM) page hits on an invalid entry in the Page Table. The presumption is that in the past, that page table entry was occupied by the very same page that has a Page Miss. Had the old page been kept open longer, it would have been a Page Hit. Increment the Idle Cycle Limit count to increase the probability of getting a future Page Hit.
Decrement—When a Page Conflict (PC) arrives and hits on an idle entry (obviously an open page). This Page Conflict can be avoided if the open page is closed earlier. Decrement the Idle Cycle Limit count to increase the probability of avoiding a future Page Conflict.
000b = 0 cycles
001b = 4 cycles
010b = 8 cycles
011b = 16 cycles
100b = 32 cycles
101b = 64 cycles
110b = 128 cycles
111b = 256 cycles
