You can try to glue the wire near the chip so that it doesnt move anymore and the solder will not be able to come loose that easy. Hot glue is certainly not a problem on your pcb. Quick fix glue should do neither. Been glueing a few times on a vga core for example with quick drying glue, but I've also fixed wire on my PCB with the same glue.
