Originally Posted by Fr3ak
i'm one of the network admins ;)
Hi, decided to join the team and help out :D
Hopefully ill be able help my uncle too and all the other ppl with cancer :) !
glad to hear it! a lot of the guys here have joined for that very reason. most of us have some type of personal connection to the diseases WCG helps fight.
Originally Posted by |Aegi3|
My dad had cancer, but he survived it. And that because a new thing called interferon A. So research def. helps. Glad to see anotherone helping us crunching.
Lets help others helping your uncle.
THe link doesnt work to join doesnt work?
I can get it while logged in, but it seems to give a "serverlet exception" when trying to access while logged out. Anyone else verify this?
I'm trying to remember if it can be done through BOINC instead. Try to DL BOINC from the berkeley site and attach to WCG accordingly.
Or wait till the link gets fixed...
Good luck and thanks for joining up with us.:toast:
-SS
Edit: I suspect the site has some problems as I'm getting this error alot now, even while signed in. Edit/
You can create a WCG account an join XtremeSystems via the WCG webpage after/while creating the account.
ya i was intend to do that, but after i click on find a team, the page wont load.
Maybe a temporarily bug :/
so can i still optimze this bonic cilent or must run with standard one?
Standard please, you'll be penalized by WCG if you optimise :)Quote:
Originally Posted by Bail_w
okay then, but 4 hrs to complete a task on a Core 2 duo 3.3ghz? WTF?
Martijn is correct..standard client please..Quote:
Thanks!
My grandpa had cancer. Now he can't walk :(
Now I'm leaving a Athlon XP 2500+ for 24/7, I hope that help people :rolleyes:
:welcome: NoRogeR sorry to hear about your grandpa! Glad to have you on the team! If you need anything please dont hesitate to ask:)
Just downloaded, set it up, and let it go. Will have it up whenever I'm not gaming.
I'm also going to try and get it setup on my mothers computer, a S754 A64 3200+
thanks man!!! it's good to have you guys online to help us out!!
Welcome, Nicksterr :wave:
Glad to have you guys aboard, the more the merrier!
2nd computer added, A64 3200+ (2.0ghz)
HI :)
Just joined the team with 3.2GHz Conroe, maybe I'll add an 1.9GHz Athlon later. I'm glad to help!
I am using WCG agent.. do not know how to:
1-say that I want to give my credits to: XtremeSystems
2- As soon as someone uses the comp to stop running to be able able to you 100% of the resources for the desired app.
TIA
BTW: it is running on an am2 and soon will configure it on my 462 :cool:
Hi; If your using the UD agent you need to switch to the boinc version available here:Quote:
Originally Posted by Duh
http://boinc.berkeley.edu/download.php
Welcome to the team.Quote:
As mentioned above, please uninstall the WCG UD agent. then install BOINC from the link provided above in Movieman post. It is straight forward. I would use the defaults, except select "Service Installation" in the "Setup Type" dialog box. Further details on installing Boinc can be found here
1) To join the XS team, click on this link. When the WCG team page appears, click on the button in the middle of the page that says "join this team".
2) As for stopping BOINC to allow 100% of the resources to be used by another application: this is generaly not necessary. Boinc is designed to run as a "low priority application". It uses the spare CPU cycles and only when not used by another application. Boinc will stop running if PC is busy. However, if necessary to stop BOINC, then once it is installed and running, you can fire the Boinc Manager, open the "Activity" menu and click "Suspend" or right click on the boinc manager icon in the task bar and select "snooze".
If you need further help, please do not hesitate to post.
462 up and running.. still gotta configure the am2
