LOL 1900s for x850... deal....
some test for the night
http://service.futuremark.com/compare?3dm05=2200676
http://service.futuremark.com/compare?2k1=9042414
gone run dice soon ;)
man those are some KILLER scores with those cards!!!
i dont feel so bad with my scores, at iffy clocks i was hitting 5k on 2k5 and 14k on 2k3, not bad for the setup in sig :P
so what kinda bost you guys seeing with a the new conroe stuff? im curious if you guys have same card clocks, on the difrent boards to compare, cause im wondering how much a gain i could see.
i will have to setup my setup for benching im kinda curious what i t can do now :P
-levi
Sticked in my X850XT yesterday too, to see what can do with it. I tried to go for first spot on ORB, it was on 51k when i looked before i started benching. But moonman had the same idea on the same evening and beat me by about 800 Points! :p: Was fun to see what this old card is capable of! :toast:
http://service.futuremark.com/compare?2k1=9106246
http://666kb.com/i/ajyxoafg7bxzijq72.jpg
Your 01 is really annoying, I'm trying my best but I cant match your card clocks. This is mine, I'm second on X800 series on the ORB. Got a 7900GS now though, so I reckon I could win.Quote:
Originally Posted by blind_ripper
http://service.futuremark.com/compare?2k1=9101924
Playin a little bit on air, need to re-mod this old bench card I suppose ;)
http://img.photobucket.com/albums/v3...X850-51438.png
Nice Nature! Eshbach timings? :)
No that's just LOD ;)
Thought so, but i'm just @ 345 FPS with 640/636. But i use 4.12 Catalyst, it is normally faster on the other tests. Which one do u use?
This is the latest approved ATI driver 6.9's I believe, I'd give them a shot. Check out Ripper's Nature ;)
Looks really strong at nature, should give them a try! :)
:p: thx , geuse ill have to buy me a X800 back again to shot that 60k out of the air .Quote:
Originally Posted by G H Z
card whase on wc and cpu air for that run long time back .
Someone already cracked teh 3k barrier on '06 with a X850? I tried it today with Conroe @ 4000MHz + X850XT @ 640/636MHz, but i only got 2887 points.. it looks really hard to break that 3k! With my old amd setup i had 2812 points, but the ati was clocked to 669/651MHz, and the Opteron 146 to 3100MHz.
Moon & tiborrr's run, all air cooled - 55498 ... and this is just the beggining, Mike, u better watch your back :D
http://service.futuremark.com/compare?2k1=9106594
http://www.oc-lab.com/slika.php?img=...t_run/0002.JPG
Very impressive. I love seeing huge heatsinks strapped to video cards. Those clocks are also real strong for air.
Has anyone tried Win2K on Conroe yet??
I'll report in a few hours.:thumbsup:
I just have to find installation CD. :confused:
I wish the only X8XX I had on hand wasn't AGP. :(
Btw Moonman, I never did forget about those 5 points. :cussing:
http://mysite.verizon.net/gautamb/18150.JPG
:D :D
Neither do I. :)Quote:
http://shrani.si/thumbs/2k318155owrv.jpg
It's at my place, remember? :DQuote:
Originally Posted by Moonman
We'll give it another go in the days coming.
:yawn2: :doh:
I'll look under my bed. There's always a backup. :fact:
Yep, my bench was on Win2k. :)Quote:
Originally Posted by Gautam
@moonman & tiborrr
What was ur temps on the X850 with that cooler? I have onyl installed a stocl Revoltec Graphic Freezer Pro, but the cooler isn't that bad!
IC now...strange though, CH is strong, but the lobbies aren't. :shrug:Quote:
Originally Posted by funkflix
Perhaps XP is indeed faster for these procs?
Well, I beleive that Win XP is THE OS for C2D.
Properly tweaked offcourse. :)
With 1.7V on GPU we had about 28 °C idle and around 45 °C load.Quote:
tiborrr, correct me if I'm wrong.
Maybe it is just because of the 25MHz more on GPU, moonman and tiborrr have? Don't know. I try to mod my cooler with a 120x120mm and try to go for more Vgpu and MHz, i was just on 1,64V.
The problem i have with WinXP is, that '01 often stops with an error-screen, something with a *dll or DirectX, but i have teh same poblem with my GX2 on XP. Never seen this happen on Win2k.Quote:
My temps was ~ the same on idle, but did not checked load. :)
Hmm well, I considered the GPU, but I'm sure you realize we're talking about mostly CPU dependent tests here, even though X850 bottlenecks C2D hard.Quote:
I too had that DLL problem with XP, even on X1900CF. Very annoying, so I switched to Server 2003. It also turned out to be about 800 points faster than XP with the X1900's, but a friend tested it on X850CF, and it was slower than XP there. :shrug:
