Originally Posted by Radical_53
Well, one thing you didn't take into consideration, when talking about the differences, is radiator performance. If you take a look at the tests that were done there, radiators do scale just like modern impingment blocks with higher flow rates, which then would double the performance difference between the very weak and the very strong pump. So then, if you continue to optimize every little bit of your cooling setup, you'd have more than a considerable performance difference :)
