Glenboy, you need really good cooling for that beast:) I ran with 4:3 to be able to hit >400FSB.Quote:
Originally Posted by GLENBOY
The good news is DFI tw will send me updated bios once they figured it out, hopefuly before Lanparty 600 release:)
Any plan of DFI tw to fix 400+ fsb : ram run 4 :3?The mobo is good for it's C/p,if they fix this issue:toast:Quote:
Originally Posted by Dumo
Dumo you are a star. I was being daft and didn't use the extra offset, doh!
Thanks again.
Tom.
my board limit at ~370mhz fsb .... i tried everything to ger higher, but nothing helped. but maybe is my the cpu reason. it´s a e6400 stepping 1 (A1) ...
Heres my DFI.
weird board.
does not like 2 gigs of ram at all.
does not work with 4 dimms filled.
does not pass 950 mhz on ram, regaurdless of using my Pentium D 930 or E6400.
cannot run 1:1 or higher, when passing 400 FSB... no matter what cas.
I've had this board for about a month, but this is the first time I used it with my E6400 that I got about a week ago.
so far, this board OC's better then my DS3 on actual MHZ, but way less on the ram....
great board, if you want low latency, and high Mhz.
http://valid.x86-secret.com/show_oc?id=111176
i wish they would get the bios worked out.
Results so far for me using latest Bios
1. The computer may boot at default CPU clock even though the post screen says otherwise? Hum, never seen this one before?
2. No apparent support for running additional SATA disk/s if you are using raid.
3. Boots to default CPU FSB if 400 split is used in the memory settings no matter what.
4. Boots to desktop quickly however task-bar (Ethernet and virus software) items load slow. Never have seen this one either.
^^^ don't have hands on info but from another dfi infinty thread a new beta bios takes care off your issues. hopefully this board is the one for me and my e6600 7950gx2 combo
Wow, Nice FSB there Kunaak:toast:Quote:
Originally Posted by Kunaak
816 still gave me fits:(
731 seems the best now, even with 4:3. Here with TT Big thypoon @ 1.56Vcore and Win XP no tweaks.
http://img99.imageshack.us/img99/299...shot202jp5.jpg
http://img99.imageshack.us/img99/441...shot203au5.jpg
http://img99.imageshack.us/img99/182...shot190vt3.jpg
So no changes for you dumo with the 8/16?
what's wrong with816?:confused:Quote:
Same Question here...i thought its better for running 1:1ratio@FSB400+Quote:
Originally Posted by eiceman
iLL
816 has problems with 2 gig and also raid atm
Just a stray 05 benchmark :rolleyes:
Anyone figure out how to get passed the FSB Wall?
A modbios or normal? Where can i get it?
how do you do the vchmod. I was on the 12/01 bios and I could not get passed the wall. Now I am at 2/27. What does the mod do? and how do I do it?
