i think the NH-U12 looks like the best bet, and its actually in stock
I think the Ninja is just to much of a pain to mount. Going with the TTower120 or the TR Ultra 120 seems to make the most sense. I wait as long as possible for a TTower 120, if not then i get the TR Ultra 120.
Looking at a review of the NH-U12, the way it mounts worries me that the caps for the Asus P5B-Deluxe be in the way and won't be able to mount. Makes me more likly to go for TTower120 or TR Ultra 120.
http://img224.imageshack.us/img224/3...uanhu127sv.jpg
Also a quote from the review:
"One important thing to note is that with these stand-off brackets in place, the processor can't installed or removed. The CPU must be installed before you install the Noctua -- and to take that further, you will have to take your motherboard out of its case in order to do a CPU swap if you have the stand-offs in place."
Mounting for the Ultra 120, looks more compatible ...
http://www.overclockers.com/articles1329/t1204.jpg
What's wrong with TT BT? $45, quiet, very decent performance, what more you want? :)
w0w why not just water cool and save the extra space and noise??
Good point. H2O holds a much bigger load than air, much better temps (helps OC), and of course, very silent. Also, mounting is so easy, you'll have room to place a fan over the mem.Quote:
Originally Posted by Eastcoasthandle
the best....:p:Quote:
Originally Posted by kiwi
The cheapest decent water cooling system is what that on Thermaltake one which is $140, a little too much for cooling.Quote:
QFT! mine idles loads ~22/~33 @ 2808mhz with 1.661v
mounts naked cores with completely stock hardware:fact:
mine is mounted horizontally on naked core...:banana: :banana: :banana:
Wha how can you mount it on horizontally? Can I get a pic or something? :PQuote:
Originally Posted by hawkeyefan
EDIT: ick you mean that its running outisde of a case and on a table yeah? :S lol @ me
I found a place that has the Tuniq T-120 for $50.00USD
http://www.coolpc.com.au/catalog/pro...oducts_id=1285
You guys might think im crazy, but i just decided to buy the Evercool WC-601 Silver Knight
http://www.performance-pcs.com/catal...oducts_id=4636
Its $60.00 with shipping, and it has idle temps of 22-25 and overclocked load temps of nowhere above 45 degrees.
-I'm about to click Cofirm Order, tell me if i shoulnd't buy this please.
HERE IS A REVIEW:
http://www.thinkcomputers.org/v2/ind...reviews&id=343
http://www.thinkcomputers.org/review...esk%20(11).JPG
Wow!Quote:
Originally Posted by hookid
Looks like a great cooler. I have been watching this thread all day, and this is the best product to come out of it. Looks like it would function pretty well. Would be nice to have some more reviews of it though, but to be honest, if that one review is right on what to expect, looks like a very unique cooler.
I took a big risk, and just ordered it. If it doesn't perform as well as i hoped. O well.....lol
i'll do a review when i get it
Honestly even with all the reviews results posted here, I put much more in real life user results with a large variety of up to date chips. And by this I mean I look at my peers here at XS and see what all the best OC'ers use... and it's overwhelmingly the Tuniq Tower 120, Coolaler, OPB, Denny, Andre, hicookie, Sierra.... all use the tower 120 on air for extreme air OC's. That's all I need to see. :) Now if I can only find one. ;)
I don't see how WCing is quieter ... WCing takes one or most likely two 120mm fans and these coolers (air) only use one 120mm. I can see it being better to take the video card fan out and the chipset fan also, but that kinda stuff really adds up ($). I think a basic (maybe swiftech kit) would cost about $350 or more after you added all that stuff on to it. At most any of these air cooling setups is costing $80CND with taxes and shipping.Quote:
WCing also is just a pita to setup .. air is just screw it on and you're done. I'll give you WCing preforms better, but for the cost i don't think its worth the extra 100 or 200mhz.
I think you got it down .. the Tuniq Tower 120 is perfect, good spacing, easy mounting, best preformance.. just gotta fine one :)Quote:
Originally Posted by gocchin
That Evercool Silver Knight looks pretty funky, especially that fan on it.
http://www.coolpc.com.au/catalog/pro...oducts_id=1285Quote:
Originally Posted by Silver Bullet
they have them here......
shipping to the US is around $15
Rather not have to order from AU, just a "little" far .. :)Quote:
Just might have to wait it out .... I can handle early August as i won't be actually building my C2D system till after my summer exams on August 14th.
20 day shipping, u'll have it in time for conroe :)Quote:
and think about it whats the difference than just waiting til august....
20 days ... that seems pretty long (i guess it is from AU). I can wait, worst case I use the stock HS for a week till the TT120 comes. I think it be worth the wait...
Try to also bear in mind because Conroe is such a cool running chip, the difference between many of the very top air cooling solutions is likely to be down to a degree or two, maybe.
$.02
Are people really debating the best air cooling on XS forums? :rolleyes:
Come on people, H20 isn't that expensive.
FWIW, I do appreciate the air benches just for reference.
I think its more the effort that you go to with water, rather than the price. Wacking a tuniq t120 on a mobo is a lot easier than anything water based that I've seen.Quote:
Originally Posted by uclajd
For me its the maintenance issue. Sometimes I have the time to muck around with things and sometimes for long stretches, I don't have the time. For the amount of gain involved I just don't want to add to the list of things I have to maintain :) Someday a maintenance free method will evolve but not for now.
