Some problems with a free time for end a beta of tests
OK... :)
Thanks fro the reply.
Some problems in due course for program finishing.
As long as the project is still alive, I am happy. :cool:
heres what i got:
E8400 at 3.6GHZ 8800GT (mainly use for physx)
I was test 8800GS in test )))
I will try speed up working on new version
P5Q-E ~ E8400 @ 3825 ~ GTS250 Gainward ~ 2x2 gb OCZ 850 5.5.5.18 ~ Se77en X64
Default VGA frequency:
http://www.pctunerup.com/up/results/...8_cuda_z_1.jpg
Core/Shader 756/1850:
http://www.pctunerup.com/up/results/...9_cuda_z_2.jpg
New alpha of MultiGPU version - http://total-oc.ru/files/foxtrot/CFB_0.4.0_alpha.zip
Final MultiGPU version - http://total-oc.ru/download.php?id=101
New version with full Fermi support - http://total-oc.ru/files/download/CU...enchmark-a.rar
Works only on GeForce 197.xx and newer
197.41 + 480gtx
i7 @ 4200mhz
http://img88.imageshack.us/img88/615...bench40a25.jpg http://img52.imageshack.us/img52/648...bench40a75.jpg
Some GTX480 lovin
http://img528.imageshack.us/img528/6717/cudabench2.jpg
Thats some major difference between version 0.4.0a and 0.4.0 , comparing them is like apples to oranges :D
http://img24.imageshack.us/img24/2136/factorialgpu.jpg
You can take correct result on GTX 4xx only on version 0.4.0a with drivers GeForce 197.xx!!!
Known issue: double GPU works only with small problem size < 500000
it doesnt work with ATI but my cpus scored well i think :S
Core i7-980X first test
http://toc.hashed.ru/getth.ashx/74dc.2010-06-08-17-02
проверить файл
сгенерировано с помощью AntiCheat TOC 0.9.8.3
Weird... the GPU accelleration does not seem spectacular...An i7-920 @ 2.2 Ghz owned a GTX260 Core 216?
GPU calculations need more optimization. We try to do it in new version and add ATI GPU support
How do you think this is going to happen since CUDA is NVidia only technology?
We will use ATI Stream Computing and wait for normal OpenCL.
:) so its not going to be CUDA factorial bench anymore? And listen i had a problem to run it with SLI GTX 480... may be u fixed it now? Only one of the cards was benching .
May be :)Quote:
Yes, we try to change some algorithms to solve this problemQuote:
New version - http://www.total-oc.ru/files/downloa..._Benchmark.rar ! We solve all problems with Fermi.
stock cooling no mods
http://img151.imageshack.us/img151/1894/90256831.png
