I cant find any 1850 GTs for my build. OH thats right you bought 48 of them! :shocked: Thats just EPIC. I dont even like large cases but I am jealous.
:worship:
:worship:
Hehehe plan is to run either my binned d920 or my still in box 940 on a nice oc and replace my ati with nvidia sli later on. ... I'm done trying to get ati cards to work eyefinity.
But all this at max OC / load / gaming but silent at the same time. Set and forget.
Just waiting on my fans/ax1200 to come in for final fitting then i can start modding with mesh, custom make my cables etc
I have one or 2 layouts in mind but I learned untill its at least mock installed you can never be sure your going to be happy with it.
Sent from my X10a using Tapatalk
Bumped down to 24 gts on rads can't fit push/pull.
If i had just gone triples on either top or front i could but i just wanted 6 quads.
Doing 5 or 6 in case for airflow, i know there not the best case fans but i didn't want to mix and match fans.
incredible build. I am contemplating getting the Mountain Mods case as well. Are you going to get the EVGA SR-2 with the six-core Xeons and 24GB of RAM with Quad GTX-480 SLI? That would complete this monster build!
Did anyone else jizz in their pants looking at this thread?
~Bex
Best compliments i've gotten on this build yet, Thanks! !!!! [up]
If I were a guy I'd have soaked my boxers and jeans! However as a lady, I can only get most and it's certainly not the same impact impressiveness level as a guy jizzing himself. But it's the only phrase that lived up to the level of excitement this builds brings upon me!
...maybe this is the reason I don't have a bf?
~Bex
MagisD
I am planning to buy the ascension case, with 1 quad, + 2 triples.
Is it a nightmare to make the cable management in that case? Do you have any tips or key tricks for it?
I have not done soldering or sleeving, do I need to do that?
Your build is still awesome! Your build is sort of my role model. Or your build and justin kerr's Drunken Monkey.
You don't have to but you will be buying phyobya ext cables and a fan controller my recommendation the new lamptrons fc touch. 1 spliter cable per rad. Plus splitter for whatever case fans you have.
Basically its a personal thing on what you think looks nice and how your laying out components. I have no front bays so everything has to go to the bottom back. So they have to reach 5-7 feet around case edge.
If you have a front bay and putting fan controller there its much shorter.
Splitter cables 1 to 3 1 to 4 fan cables.
Extentions cables are 1 to 1
Ok OK
I have a Zalman fan controller. I think it's a ZM-MFC1 PLUS one. So I can use splitter cables for that one when I am using Scythe Gentle Typhoon 1850 fans?
Nope, well you can but not recommend 1850gts just to be on safe side are 5 or is it 10 watts power draw starting up. Ya need a heavy duty fan.controller
I thought that: Watt = Volt x Amps
If I am correct: The startup voltage for the GTs are about 12 at max?
Watt = Volt x Amps
W = 12V x 0.360A
12V x 0.360A = 4.32W
The Zalman ZM-MFC1 has 7W/channel. So I can not have more than 1 fan per channel.
Maybe I should buy the Sunbeam Rhobeus?
It has 20W/Channel!
your right I double checked the thread where i asked it.
Just time be safe consider 5 watt startup and 1 watt draw while low rpm.
Or the Sunbeam RHK-EX-BA Rhobeus Extreme!
It has 6 channels, 30W on each! :)
Oh my god I can't wait for my USA vacation this winter! :D
Any chance a mod could clean out the fan related posts above?
Nice build / can't wait to see more...........
MY GOD :clap:
Ax1200 arrived yesterday still waiting on fans but its time to break out the mdpc-x.
