Wow:eek:
Please don't surprise me with such a huge clock;)
I'm dying now:D
Nice run, Peter:clap: and happy new year:):):)
Wow:eek:
I'm dying now:D
King Sham is da man ! :up:
I made some pictures of that monster here : http://www.pt1t.eu/?p=254
Screw 1500 core, did i see 3000 shader?? :shock:
Does it still live... :stick:
Thanks Pt1t, so with the 3 slot backplate how are people supposed to run tri-sli or more without removing it?
does anyone know the meaning of Direct CU?
CU is copper...
direct copper... i think it means huge cooler :D
You can use it with normal one :p
http://www.pt1t.eu/?p=277
http://www.pt1t.eu/public/Pt1t_EU/06...2/IMG_3550.JPG
very cool! Congratulatons.
New stage with this card :D:
http://www.pacificgeek.com/productim...000-T-32MB.jpg
Amazing clocks Peter :eek: , now anxiously waiting the release of this beast :D , great work :up:.
tri sli will be possible on the M3E f.ex..
http://www.legitreviews.com/images/r...us-M3E-Top.jpg
using slot 1, 3 and 5 should do the trick :)
i was watching my friends from Team Merlion bench the direct CU a few days ago, spyboy, shrek and yantronic pushing the rig:
http://img825.imageshack.us/img825/5118/031550mhz.jpg
too bad the gt1 was a low run gt1...
http://img714.imageshack.us/img714/4462/10134.jpg
Good benching by these guys!
is that the same gpu you had previously benched with?
Pushing the limits .....
If this isn't a special card, it's really gonna terrorize the bot/ORB.
any stock -card results without mod yet?
how about availability in europe?
here is another way for vcore mod which i prefer so that the vgpu adjusted will not rise when gpu runs warmer, and it makes the voltage droop properly under load which can be good as long as you set it at a higher voltage under idle.
http://img831.imageshack.us/img831/1098/prefer.jpg
which controller is this?
close enough...
just kinda curious...
thanks
