WOW good JOB!!! :eek::D:clap:
Ok now consider support for ASUS M3A79-T :D:D:D
will u be adding support for the 790gx boards, I have one coming in the mail, i've always enjoyed all the different apps you have made. Good work!! If you need any info from my board just ask.
Would this work to fool the Intel compiler into thinking it's compiling for an Intel chip and thus not penalize the AMD machine?
Native Specialist 1.2 build 1214 has been released!
http://cbid.at.tut.by/work/ntspec_mini_1.png http://cbid.at.tut.by/work/ntspec_mini_2.png http://cbid.at.tut.by/work/ntspec_mini_3.png http://cbid.at.tut.by/work/ntspec_mini_4.png http://cbid.at.tut.by/work/ntspec_mini_5.png
Added full recognition of the following AMD processors:
- AMD Athlon X2 7450 processor (OPN AD7450WCJ2BGH)
- AMD Athlon X2 7550 processor (OPN AD7550WCJ2BGH)
- AMD Athlon X2 7750 processor (OPN AD7750WCJ2BGH)
- AMD Phenom 8250e processor (OPN HD8250ODJ3BGH)
- AMD Phenom 9150e processor (OPN HD9150ODJ4BGD)
- AMD Phenom 9350e processor (OPN HD9350ODJ4BGD)
- AMD Phenom II X4 920 processor (OPN HDX920XCJ4DGI)
- AMD Phenom II X4 940 processor (OPN HDX940XCJ4DGI)
- AMD Athlon Neo X2 6650e processor (OPN ADD6650IAA5DO)
- AMD Athlon Neo X2 6750e processor (OPN ADD6750IAA5DO)
- AMD Athlon Neo X2 6850e processor (OPN ADJ6850IAA5DO)
Added support for the newest AMD Phenom II and AMD Athlon II processor families:
- AMD Phenom II X4 9xx/8xx/7xx/6xx/Bxx series
- AMD Phenom II X3 7xx/5xx/4xx/Bxx series
- AMD Athlon X4 6xx/5xx/Bxx series
- AMD Athlon X3 4xx/3xx/Bxx series
- AMD Athlon X2 4xx/2xx/Bxx series
- AMD Phenom II Neo X4 family
- AMD Athlon Neo X4 family
- AMD Athlon Neo X3 family
- AMD Athlon Neo X2 family
Download link, 922 KB.
What kind of CPU will be the AMD Athlon Neo?
got this using vista 64 bit, 32 bit support only?
http://i278.photobucket.com/albums/k...d/Image1-8.jpg
soundood, I'm sorry, I haven't tested my driver with Vista 64-bit edition yet.
Hi VVJ, can u help me :confused:
My X3 8450 can't read core 2 freq. with ver. 1.2, core 1 and 3 sound good :D
http://img.techpowerup.org/081215/8450.jpg
Hi, iMAX!
Thanks a lot for the response! There was something wrong with affinity mask for the second thread. As you probably know, Native Specialist monitors CPU Frequency, VID, FID and T-Power for each core in a separate thread. And this feature is the evident benefit comparing to another software on your screenshot above. So, I have just made a minor improvement in the thread affinity assignment routine. This should help. Thanks for the notice again and check up the new version, iMAX! It would be interesting to see a correct P-Rating of your CPU :)
Native Specialist 1.3 build 1218 has been released!
Added full recognition of the following AM2r2 AMD Family 10h processors:
- AMD Phenom X3 8450e processor (OPN HD8450ODJ3BGH)
- AMD Phenom X3 8550 processor (OPN HD8550WCJ3BGH)
- AMD Phenom X3 8750B processor (OPN HD875BWCJ3BGH)
- AMD Phenom X4 9450e processor (OPN HD9450ODJ4BGH)
- AMD Phenom X4 9600B processor (OPN HD960BWCJ4BGD)
- AMD Phenom X4 9750B processor (OPN HD975BWCJ4BGH)
Added full identification of the third-generation quad-core AMD Opteron processors:
- AMD Opteron 2376 processor (OPN OS2376WAL4DGI)
- AMD Opteron 2378 processor (OPN OS2378WAL4DGI)
- AMD Opteron 2380 processor (OPN OS2380WAL4DGI)
- AMD Opteron 2382 processor (OPN OS2382WAL4DGI)
- AMD Opteron 2384 processor (OPN OS2384WAL4DGI)
- AMD Opteron 8378 processor (OPN OS8378WAL4DGI)
- AMD Opteron 8380 processor (OPN OS8380WAL4DGI)
- AMD Opteron 8382 processor (OPN OS8382WAL4DGI)
- AMD Opteron 8384 processor (OPN OS8384WAL4DGI)
Added full support for the following AM2r2 quad-core AMD Opteron processors:
- AMD Opteron 1352 processor (OPN OS1352WBJ4BGH)
- AMD Opteron 1354 processor (OPN OS1354WBJ4BGH)
- AMD Opteron 1356 processor (OPN OS1356WBJ4BGH)
Everything seems to work except the ram issue. Right now I am running 1066, but the program is saying 800 max, I have circled it, any ideas
http://img522.imageshack.us/img522/2...ivespecef4.png
Loving this program. Works great to throttle up and down my CPU Freq. by whatever i need it for at that moment.
HondaGuy,
I would help you if you could provide me a dump file. Please, run NtSpec.exe with /DBG parameter to create the text dump file.Quote:
I was reading the last 2 pages of this thread and I still cannot understand what more this programm has to offer than the cpuz and AOD.
Can someone enlight me please?
What is with this malicious program here?
Virus scanner says
ntspec.zip 922 KB
TR/Crypt.ULPM.Gen
HondaGuy, please don't worry. Just make a shortcut to the NtSpec.exe file. Then choose its properties. Type /DBG in the Traget field.
http://pic.ipicture.ru/uploads/08122...uTV2p3WE62.gif
Now run the shortcut to create CBIdReport.txt file. Let me know if you need any assistance from me. Thanks!
Bump for a cool program. I have Vista x64m but Im using an older Central Brain Identifier to change my AuthenticAMD string to a Genuine Intel. I don't want to be discriminated against because I use an AMD CPU by the software.
I didn't know this still existed. Do the new versions work with W7 64? I want to change the CPU string in CPU-Z for benchmarks to include my name.
Nice... you willing to try running y-cruncher using AuthenticAMD vs. GenuineIntel strings?
I'd be a good test to see if the Intel Compiler is doing anything funny to discriminate against non-Intel chips... ;)
You'll need version 0.4.3 or later. I didn't start using the Intel Compiler until sometime between 0.4.2 and 0.4.3.
