The whole system will be around 30dB or little less :up:
im still wanting know know when your mass producing so we unfortunate can get our hands on one.
very sexy build, btw.
Never, ever thought about phase change until now and have only done one small WC'ed system ......so for those out there with experience have noob question. What does one do if there would be intention to cool multiple GPUs? Would this be an independent loop with its own rad,etc? :shrug:
yeap, you would do either a watercooling loop just for the gpu or you would need a second evap to phase cool your gpu.
After 2 hours on load. :)
http://ld-phasechange.com/images/Lit...seChange/2.JPG
http://ld-phasechange.com/images/Lit...seChange/1.JPG
Kind Regards
i guess the first watt-o-meter is the heat load or is it the the power consumption of the phase change unit ??
Power consuption @ 260W heatload:
http://ld-phasechange.com/images/Lit...seChange/4.JPG
Power consuption @ 215W heatload:
http://ld-phasechange.com/images/Lit...seChange/3.JPG
Kind Regards
so i guess around 400w power consumption at 300w heatload ??? But thanks for those screen shot of the power consumption.
Very nice all around. Any pics with the water cooling installed also?
Some more pics:
http://ld-phasechange.com/images/Lit...omplete/10.JPG
http://ld-phasechange.com/images/Lit...omplete/11.JPG
http://ld-phasechange.com/images/Lit...omplete/12.JPG
http://ld-phasechange.com/images/Lit...omplete/13.JPG
http://ld-phasechange.com/images/Lit...omplete/14.JPG
http://ld-phasechange.com/images/Lit...omplete/15.JPG
Power consuption on 300W heatload:
http://ld-phasechange.com/images/Lit...Complete/9.JPG
Will this case fit a SR-2? Or do you have plans to make any modifications for one?
EVGA SR-2 fits in that case without any problems and all 4 way SLI motherboards too.
Kind Regards
Superb case, I have no knowledge about phase cooling but this makes me wanna get into it:cool:
What kind of wattage does it pull while idle, any idea? Just wondering if this would increase my electric bill much.
IDLE:
http://ld-phasechange.com/images/Lit...omplete/16.JPG
Best Regards
Very nice design! :clap:
Forgot to tell that HDD cage can be rotated.
http://ld-phasechange.com/images/Lit...ases/HDD/1.JPG
http://ld-phasechange.com/images/Lit...ases/HDD/2.JPG
http://ld-phasechange.com/images/Lit...ases/HDD/3.JPG
http://ld-phasechange.com/images/Lit...ases/HDD/4.JPG
http://ld-phasechange.com/images/Lit...ases/HDD/5.JPG
http://ld-phasechange.com/images/Lit...ases/HDD/6.JPG
Kind Regards
Nice feature to be able to turn the HDD cage, really nice work.
is this a group-buy? where do I sign up?
support for mounting 1.8" or 2.5" in the HDD cage would be cool
What do you think? :) 23dB at full speed ;)
http://ld-phasechange.com/images/Lit...ases/new/1.JPG
Kind Regards
23dB? That's incredible!
Silent phase change :up:
I also added sound isulation on side pannels and you can regulate fan speed, If you are not benching or something similar you just lower rmp and that's it :) Button for lower speed fan will be on the last PCI Slot.
Kind Regards
