9NDA3+ info in the first page is wrong, Vcore is only 1.4-1.6V.
i have the bios from 1.11.2005 - it goes more then 1.6v ;).
when i should do the vcore mod on MSI K8 NEO2 Platinum what size of the vr-pot should i use in ohm???
I have news. I read here that the XP-90 wouldn't fit on the MSI K8N Neo2 when also using Corsair Pro memory (the ones with activity leds). Well, since I got the memory a while ago and I decided do that upgrade without knowing this issue, I was ready to check for myself that, now the news: The Thermalright XP-90 DOES fit on a MSI K8N Neo 2 Platinum when using Corsair Pro memory, I'm using a pair of 3200XL Pro memory, the space left between the memory and the heatsink should be about the thickness of a common CD.
However, and don't see the point to use this memory with this setup, the leds can't bee seen since they are totally covered by the XP-90. Well, if you try to look at them through the heatsink you would.
Just ditched my :banana::banana::banana::banana:ing K8N Neo2 for an Abit AV8. As for a warning you might want to add that it has *issues* running in Dual-Channel on alot of RAM. <uncluding Hynix BTD43>
Single channel works fine to the normal 270 but in DC it wont budge above 220.
Gonna get my new TCCD on FRI and see if that helps, if not ill try some DTD50
Someone should do a nice guide like that for dfi ultra/sli-d's :toast:
Someone should refresh the list with NF4 mobos(this thread is a little bit outdated,isn`t it)
:stick: :confused: :wierd: :hehe:Quote:
Origianlly posted by GIGAFAN
Someone should refresh the list with NF4 mobos(this thread is a little bit outdated,isn`t it)Quote:
2500+@2425,6Mhz 220FSB 1,8V agresive;GA-7N400 pro2;2x512Mb@440Mhz 8-3-2-2 GEIL ULTRA-X;3D COOLER PRO;MSI RX9800 PRO
I am looking for upgrade parts mobo ,cpu,grafic ,and card.Yor post talks about your personality :stick: (if you have one),so i don`t have to spend any kind of words for you :p: (by your atitude no one who hasn`t made an upgrade allready shouldn`t post a reply)
BTW your nic supose to scare someone? :lol: :lol: :lol:
Hey, it's all in fun (note I only posted emoticons and didn't say any harsh words), if you can't take a little ribbing, then it seems your the one with the poor personality. Haven't you ever experienced any tomfoolery? My friends and I bust each others balls all the time. Lighten up, and enjoy the forum, I have for three years. So here is a hearty WELCOME to you.
:banana4: :banana3:
That was a joke without a solt(that how we say it my country)=bad joke.I don`t know you(for now) so you can`t make such personal jokes.You didn`t have to wright anything to look as a bad joke.Thanks for HEARTY WELCOME.I am not stiff as a board,but that was over the line.Read this:http://www.xtremesystems.org/forums/...ad.php?t=53325
That shoud explain something!?Try to be less hearty :lol: next time with newcomer. :toast:
P.S.:I haven`t noticed such jokes on this forum. ;)
Im having some problems with OCing my 3200 cos i can't get enough vcore on my mobo (tops out at 1.55) any one know any way around this?
Hi Ocing friends!
Need some help with my 939 rig now!
I got winchester 3500+ works onlow temps with neo2 first i noticed the board bootet and gets off again because of bad contact now i modded the cpu kit and all fits in but.....
it ran 30 min idle and stressed showed 40Celsius everytime so thats pretty nice but then it worked his way up to 42,45,48,50=>freeze but why? my phase change says -50@ evap. i used 1,5-1,6Volt
if i let it run long timeit show s cpu gets hot and powers down?! never got this problemwith S754 mobios (k8n,Dfi)
hope someone knews help
ThanksinAdvance
seEn andL
PS: sry m8s 4 bad english
some facts about my Abit AV8 3rd eye and my winnie 3000+.
-doesn't work with my Antec NeoPower 480 :( :( :( ,but works fine with my Thermaltake 480.
-Thermaltake Tower 112 bearly fits on this mobo,so try to install carefully
-fluctuating CPU temp,almost to 10 degrees variation,high cpu temp
and some good things:
nice overclocker,FSB up to 300 Mhz :D LDT 3x
update:
2*512 Corsair 4000PT v2.1 in Dimm 3&4 250 Mhz >8-4-4-3 2T 2.8v(crash @1T)
same ram in dimm 1&2 250 Mhz >7-4-4-2.5 1T 2.8v stable
Zildjian,
there's a known problem with Antec PSU's, if you contact Antec they'll have it replaced for you.
thnx man for the info,i'm sending an email right now ;)Quote:
Originally Posted by thebluesgnr
ok Im building a new pc now, I have a CPU that does 9x300++ tagan 480w one old hdd (120gb 7200 rpm) radeon 9000pro(I know...) and I was going to buy MSI K8N Neo2 Platinum NF3 Ultra but its konda expensive here (200$) hmm do I have any other options, I just need a board that does 320 fsb stable...
hmm I was checking the posts and u say Gigabyte GA-K8NSNXP-939 is more expensive than MSI K8N Neo2 Platinum NF3 Ultra and here in slovenia its the other way around Msi is double the price of gigabyte. is voltage stable at 1.6v on gigabyte or not? please help, so many mixed opinions here I dont know what to buy. as I sad Im planing on 300x9 at 1.55-1.6 volts and I have a chip that can delivere it, I just need a mobo...
I found the Giga 939 Ultra board to be stable and have good throughput to storage but it was not a good overclocker -- my cheap EPoX is a great overclocker!Quote:
Originally Posted by Eru
hai......
can anyone help me on how to check on Vdimm voltage my msi k8n neo2 mobo me using ocz ddr booster coz my enermax psu doesn't support -5v that why i can't get vdimm voltage reading on my ocz ddr booster running on my windond Utt ram.
Is the any kind of software that i can check all the voltages on this mobo
thank you
:mad:
only way to check vdimm is by using a multimeter.Quote:
Originally Posted by raydelee
As far as i know bios and the included software can“t read it out.
Updated with more A8V info, thanks to babyelf
no problem :D
Just updating what i researched for my own AV8
added some things i found in this thread :)
thx, added :)Quote:
Originally Posted by caligula
thx for the info about the first slots not liking 512mb sticks in dual channel jlccarv :)
what should i add?Quote:
you do realize that your htt multi isnt really 5x right?
thx scorp, will add that to the infos :)
welcome to XtremeSystems :toast:Quote:
Originally Posted by kublikhan
added it to the list :D
thx for the F7 tip for giga users Chouny, added to the list :)
PorkchopExpress, the sata slots 3&4 on the epox board will NEVER be locked, a bios cant fix this...
thx Gauss for the xp90+corsair xl pro infos :)
thx Zildjian for the corsair 4000PT info :)
i hope this doesnt dissapoint anybody, but i think this was the last time i updated this thread :D
if i have time enough i might make a new thread similar to this about nf4 boards, but atm i dont think i have time... sorry... if you really want a thread just get together with some other guys here on xs and do it yourselves, send me a pm and i will help you and sticky it :)
thx a lot again to all the people who contributed to this thread and made it this great collection of infos it is :toast:
Hi there.
Does anyone know how to turn on 1T command on Asus A8v d.? I have 2x512 memories in dual channel.
For the epox 9nda3+, you list that SATA ports 1&2 can't be used with arctic cooling, but they can easily be used if you just get one right angle connector and one regular cable and cut it down so that you can bend it close to the plug. I've attached pics for clarity, I was using an Arctic Cooler just fine, but now its been removed so you can see the connectors really well.
Also, on the 9nda3+, I'm using the Zalman 7000AlCu with no problems at all, not sure if its different than the 7000A that you said doesn't fit on this board, but I know a lot of people are using the 7000AlCu, and there's no issue at all, you can still use all the Ram slots as well
Originally Posted by swiharta
Thanks I made it work with a BFG Geforce 6800 OC even!
hi guys! been following this thread for some time, because i want to upgrade to an a64 but don't want to part with my agp card. did any notice that dfi has posted the specs for "lanparty ut nf3 ultra-d" on their site. hope you check it out so i can join you guys with a64s. thanks
There is another much simple solution: To use the SATA cables of the MSI K8N Neo2 Platimun.Quote:
Here is the photo with BFG 6800 and NV Silencer5 working OK.
http://img294.echo.cx/img294/9774/sataepox7xh.th.jpg
:banana:
Received my fx53 today
going to try the abit board a8v
but i see mixed results about em
i see refrences to memory bh5 tccd???
i have 2 stix of cmx512-3700 :confused:
what do i have in that terms
thanks for any input
here is some pics
yes dimm 1 is tight but i was able to get it in with heatsink on
abit AV8
Are we gonna put the DFI NF3 Ultra-D on here at some point?
I'm interested too. Any experiences width that MB till now?Quote:
Originally Posted by Fission
have some things to add about the Epox 9nda3j:
- u cannot mount the vm-101 and an Xp-90, UNLESS u invert the vm-101, and use an inverted motherboard case.
they put the AGP port too close to the CPU. i've seen other boards that have the sata ports between the CPU and AGP, on this board the sata ports are between the AGP and first PCI slot.
- u cannot use DIMM 1 and DIMM 2 with XP-90, by mounting the XP-90 with the pipes torwards the LPT Ports [not torwards the RAM]
- u can use DIMM 3 and DIMM 4 with XP-90, BUT BARELY, i've managed to scratch my beautiful c2pro, on some stupid xp-90 fins while installing the RAM with the heatpipe top end facing the RAM.
- inverted motherboard cases might require some special cables to the power connector, when used in conjuction with Xp-90, u have to insert the power cable underneath the XP-90 fins, while coming with the cable from below..very tricky.
as for the XP-120 things are even more restrictive i guess.
the other stuff has been said already, most annoying thing is that my ram won't do 2T, even at stock values :(..but oh well, i've got 280MHz out of 110USD RAM.
I have a question,
for the MSI K8N neo2:
Does it report something like 10 degrees to much on stress temp?
and you have to install the 1.36b for 1.9vcore, can't you get this much Vcore with the official one?
xyus
I'm using BIOS v1.8 and 1.85v is maximum core center will offer but this is sufficient for processor width nominal 1.4v (Venice).
Thx for the tip.
xyus
Anyone having USB2.0 issues with the new 1.A bios for NEO2 .. or isit just me?? Can no longer locate the UBS1.0/2.0 option in the bios. I suspect thats the thing that's limiting me from enabling usb2.0 in Winxp (stuck with usb1.0 for the time being)
I'm trying to use my dual channel kit with ocz booster, but :rolleyes:Quote:
TIP: use slots 1&2 for BH-5
TIP: use the ocz ddr booster in slot #2
-- posted in wrong thread -- ignore :/
Where else but here to post this message...
I have a DFI LP Ultra D s939 motherboard with an AMD X2 4200 and ATI x800xtpe.
I'm looking for a fix so I can run this combo with windows VISTA.
The problems lies with an error 43 display driver error due to a conflict with the above hardware on NF3 based motherboards.
Help with a fix?
Anybody Using x2 4400 (89w, 2x1m 939) and or on an ASUS A8N-SLI Premium, and also the x24200 (65w, 2x512 AM2) on the ASUS CROSSHAIR or any one of them? Just wanna know if this is the right tread to get input or feedback on any of these parts.
