Nice case Knet370. :)
Iandh, that case is just brilliant! Even though the form of it isn't my taste, I would love to have that one sitting on my desk due to all the details, that start sky is beautifull, and the front and the power and reset buttons and I could continue, I really, really love the details in that one :)
Are those seperate LED's or the 4 led fans? Looks pretty sweet
@knet: got plans of changing the ram cooler's leds? the color kinda doesn't work with your tubes
Nice rig!
That "Power/Reset" button is INSANE!!!
Good work!
Simply. WOW.
Awesome job there mate!
Some pics of my case :
http://img502.imageshack.us/img502/8866/ganz1sh2.jpg
http://img372.imageshack.us/img372/7348/ganz2xm6.jpg
http://img293.imageshack.us/img293/7447/ganz3zq0.jpg
http://img372.imageshack.us/img372/3175/blende2wu8.jpg
http://img355.imageshack.us/img355/2570/bel2yw4.jpg
http://img515.imageshack.us/img515/3749/bel1kc4.jpg
http://img294.imageshack.us/img294/8980/ganz5vk9.jpg
The next step will be a window made by a CNC and a new frontplate designed by myself :
http://img90.imageshack.us/img90/716...vornneuzp8.jpg
hmm...nice case and setup...may be not exactly the XS tubing OD/ID :D
edit: oh you also got an Eheim pump, very unusual here ;)
Winni very nice setup. What res is it ? It isn't EK...
And nice project of custommade frontplate, congratz m8 :)
It`s a Cape Corp Coolplex Pro 10 external ->
http://www.aquatuning.de/product_inf...-external.html
I´m glad you like the design of the frontplate :)
EDIT: Yay, I grow up and lived the first 11 years of my life in Poland too ;)
I was planning a very similar setup but I hessitated when told my eheim 1048 wouldn't have enough juice for 2 rads and 3 blocks. And you have yours with 4 blocks and 10/8 tubing :shrug:
Are you getting good temps with that? Any problems?
BTW love that murderbox style front
Its a modded eheim, its called Innovatek HPPS + 12V,here the link : ->
http://www.aquatuning.de/product_inf...-12V-Pump.html
The flow in the system is not a problem even with the restrictive EK Supreme, the water in the res is always blubbering strong.
The Q6600 @3,4 Ghz and 1.325V is 35°C@ Idle and 46-47°C @ load.
The 8800GT @ 700/1030 Mhz ist idle @36°C abd load @ 44°C.
The components :
1 x 120mm Radiator
2 x 240mm Radiators
1 x Innovatek HPPS + 12V Pump
1 x Heatkiller NB
1 x Heatkiller SB
1 x Heatkiller Mosfet
1 x Zalman 8800Gt Fullcover
1 x EK Supreme
1 x Caper Corp Coolpelx 10 Reservoir
Pump -> 120mm Radiator -> 240mm Radiator -> EK Supreme -> Heatkiller Northbridge block -> Heatkiller Southbridge block -> 240mm radiator ->
Zalman Fullcover 8800GT Block -> Heatkiller Mosfet Block -> Cape Corp 10 Reservoir
EDIT: It doesnt matter which tubing you have, everything over 10/8mm does not increase the flow or makes better temps.
The same goes for the pump, ist enough when the water circualtes with 60L/ hour, everything more does not make better temps.
( an exception are blocks like the D-Tek Fuzion, there the higher flow makes better temps )
Winni, what are you using to house your hard drives?
Im using a box for the HDD, its called Scythe Quiet Drive :
http://img183.imageshack.us/img183/3...hddcoolqj4.jpg
Its one of the best AND cheapest boxes existing, it won much reviews against other boxes. The price here in germany is about 30 Euros.
Winni, I have to admit that for a new poster @ XS, your posts are just it ;)
Ooo, thank you, really appreciate it :)
@Winni
Nice build I especially love the compression fittings, they give such a clean look. Are those bitspower fittings?
thx
I unfortunatately dont know bitspower, they are normal screw on fittings :
http://www.aquatuning.de/product_inf...ting-G1-4.html
Final Pics of Koen Server!:
http://i2.photobucket.com/albums/y32.../Final2/01.jpg
http://i2.photobucket.com/albums/y32.../Final2/02.jpg
http://i2.photobucket.com/albums/y32.../Final2/03.jpg
http://i2.photobucket.com/albums/y32.../Final2/04.jpg
http://i2.photobucket.com/albums/y32...r/Final/08.jpg
Also Modblog Here!
