FragTek,
Stepping on that 180 is?
FragTek,
Still testing (good watercooling, neither chilled nor anything else special):
http://valid.x86-secret.com/show_oc?id=57188
http://valid.x86-secret.com/cache/57188.png
Still with heatspreader on it. Will squeeze it a bit more without HS and stable dual-Prime will follow. 2950-3000 MHz should be easy with it.
@ FragTek
2700 @ 1.52V is quite worse for 180 Opteron. Maybe temperature is holding you back? Btw SP2004 is crap - use two instances of Prime 24.13 or 24.14.
Some of my 175 can do 2800 at 1.47 :
http://mitglied.lycos.de/xxmartin99/...0@1.472_6h.png
And this is still not the best I have. But need some more time for testing the rest of them. :)
Actually that speed isn't too shabby for this processor... Don't know where you've been looking.
And yes the temps might be holding me back, but never fear I just got the hookup on a PC Ice v2000 vapo that's supposedly supposed to do -45*c @ 1.85vcore full load :banana: :banana: :banana: :woot: :banana: :banana: :banana: It should be in within 2 weeks mefinks.
Reports when it comes in! :D
Edit: @phadeout: CCBWE 0543UPMW
hi
my 165 CCBWE 0546SPMW does:
2450@stock
2500@1.392
2700@1.55
2800 weaker core is core 0 (fails in 2minutes)
all that with stock hsf, closed case not so well ventilated.
i'm satisfied 4 the moment more tests with screenies asap :)
Well here's my results with a 0534 SPMW 165. No proof of stability here but it's running great, 32hrs of prime and lots of games :) This is with 1.475 set in BIOS, I'm really hoping to lower it to 1.45
http://img208.imageshack.us/img208/1...tled5ys.th.jpg
awesome chip there congrats...I have a new untested 165 0534 MPMW...I would love you settings and perfromance...
Good luck with yours, maybe you'll get similar results
About time I had a good chip though, glad I jumped on the bandwagon early.
Anybody got one of these recent Monarch 165?
that should be a better stepping than my TPMW of the same week. I've seen those do 2.8 on air @ 1.5V.Quote:
Originally Posted by FragTek
Though, that is just one account...
Not bad. My 180 also does 2.7 pretty reliably at in the 1.4ish range. While I'd love to be hitting 3 ghz, I don't think i'll be hitting it on air or with my current memory.Quote:
BTW: It's an 0543
Mine will be here on Monday.Quote:
Originally Posted by Martin Cracauer
I've been toying with the idea of swapping mobo's... I have this odd suspiscion that it might not be performing up to potential. Perhaps I'll make a board swap when I get the new PC Ice unit in.Quote:
Originally Posted by phadeout
I got a lot of cheap 165's and most of them did 2700 @ 1.52-1.58V.Quote:
Correction....not sure why but FedEx just showed up!! :woot:Quote:
Originally Posted by wickedld9
My Opteron is VERY new.
OSA165.....
CCBWE 0546 MPMW
Ok, now can you please give us the 36 hours dual-prime stable overclock before I leave my house at noon? :)Quote:
:lol: ;)Quote:
Don't know why, but I found that extremely funny. Thanks. :toast:
Well, after more burning and tweaking, I'm now running reliably (dual prime large and small fft, memtest, FEAR, 3dmark05) at:
2.75Ghz @ 1.55V and 49*C
2.77 is not totally stable, so I think I will just avoid 2.76 as well. Maybe with more burning, 2.77Ghz can run dual prime for about 5 minutes.
3.05ghz dual prime stable @ 1.65 actual dmm v-core reading on A8R MVP. Not sure I want to play with more volt now... I will probably look at what screenies I can get now.
Opteron 170
0546SPMW
Playing with low vcore for some cpuburn K7 and prime sessions
@2200mhz at 1.216v
http://www.fileshosts.com/DFI/NF4_SL..._cpu1_1_tn.jpg
@2450mhz at 1.312v
- cpu1 needs help :)
No overclocking for me. 1 core errors out of Prime in less than a minute if both are running. Going to do some more testing but I think it's DOA. :(
Ouch. Sorry to hear :(Quote:
At stock settings?Quote:
Wierd, this opty which can happily dual prime @ 2.7ghz and up to 2.75ghz on air only likes 3.05ghz on phase. I haven't been able to get it stable beyond that yet. It is rock solid at 3.05ghz though... Good enough for daily rig of mine for sure but bit disappointing considering it did almost 150mhz more on air than my x2 3800 did. Was hoping for 3.25ghz dual prime stable.
what sort of temps?!?Quote:
Originally Posted by jinu117
cold bug maybe ?Quote:
