In Abit very hard to hit 600Mhz ram freq. Please test same settings, try maxmem 600!
btw mobos have 1066 strap give the best performance in 1:1.
@Vapor, 1066. Thanks, I'm learning about this board. QuadGT. I've been working with some of those OS things and don't have the right combo yet. Way far away from some.
I'm still watching...:fact: Looks like I know what I'll be doing while fighting the jet lag now. ;)
I dunno about this though, that 14.xx was damned hard. My ram is capable of the big speeds, rather the mobo starts binding around 650 it seems. How to pull off a 32M at 660 is just beyond my comprehension. Everything has gotta be in place and oldscarface has definitely got it. :p:
Heh, depending on how things pan out perhaps you can have another go with this stuff. :DQuote:
Originally Posted by Vapor
c.h.r.i.s- the Commando is supposed to have better vdimm regulation than the P5B. I too cannot 32M well at higher than 2.65v or so...have you tried lower vdimms than on the P5B? The vdimm drop/droop should be less on the commando compared to the p5b.
Oh and btw, sub-10 can be done at about 4920-4940MHz with today's hardware if anyone so pleases...I can assure you of that. ;)
me too cant run spi @ >2.65v vdimm, between 2.6v and 2.7v it seems too little gain in rams mhz... for me 2.45-2.55v on p5b was the best for ram benching. lowered the NB voltage also helps stability.
coop, tried maxmem 485, 512, or 600. set affinity to Core 1 for spi. and then copy wazza with 2.4gb works perfect. in my P5B boot at Trfc = 35 was faster than 25. one thing, Use XPLite (edit with nlite).
I'm still under 15min :fact:
http://img221.imageshack.us/img221/4...59750skuw6.jpg
very nice run.... 1066 strap awsome...
now you're playing secret huh :D
Your pic is corrupted I see some blue polygon on it :) :D, let me guess you start to play with some ram eat software?
He over@locker886,
That score is pretty impressive for those memspeed. :clap: :up:
It seems that I have to go benching again. :D
My run.... Im curious to what the acceptable performance product at around this speed? Sorry im still new at this but comparing my PP to Gautam and Misko's score, Im wayyy off lol..... I understand that both of them are about as good as they get but I just want some opinion on where Im at.... thanks...
http://www3.telus.net/luis99/oc/50.563.jpg
Thank you for your suggestions.
very nice coop :toast:
Quad GT 1:1 @ 1066 strap is so powerfull.... i need that board to compete with you guys... stuck with P5B now...
After probably 20 tries this is as close as I can get..(over@locker886)
12.xx Category :toast:
im closer :D
Tried 3590mhz, but got result 13m 0.037s LOL.... 0.037s to 12m :D, what tweak do i need more? anyone can help? my subtimings already too tight, so i need windows tweak... how much the paging file do you guys set? thx
^^ That is a very nice 12.xx
I could not let it go. I had to keep trying.
One more
:D 4/5 vcore1.520v vdimm 2.447v vmch 1.734v vtt 1.437v
Got as close as +.298 with 3276 and those Ballistix 8500's rock.
:confused: ;)
http://premium1.uploadit.org/fredyam...-3600.1MHz.gif
(Setup)
M/B: ASUS P5B Deluxe WiFi-AP 6CM0AID (Bios 1101, Vnb/Vdimm Clip mod)
M/B Bed: ARC Bed Rev.5.0 PRO
CPU: Core 2 Duo E6600 L632B086(35634076)
CPU Cooling: Air Scythe Infinity + Delta TFB1212GHE x 2
Chipset Water Cooling: Alphacool Xtreme Pro 360mm Kit + NB:Alphacool NexXxoS NBX-A, SB:Alphacool NexXxoS NBX-N
Memory: Team Xtreem TXDD2048M1200HC5DC 1GB x 2
VGA: ATI 3D Rage PCI 8MB
HDD: Maxtor 6L080P0 PATA 80GB
Power Supply: OCZ PowerStream 520W
Vcore: 1.600V(Bios), Vdimm: 2.608V(Actual), Vnb: 1.893(Actual), Vio: 3.472V(Bios)、Others:Max in Bios
OS: Windows Server 2003
MEM: 2:3, @Bios: 4-4-4-4-4-4-25-4-9-4-9
Others: FSB400@boot, SetFsb2.0, MemSet3.2, ERAM2.11, AutoGear, MAXMEM, Copy-Waza
Thats very very impressive Fredyama :yepp:
very nice Fredyama.. :)
:clap: :clap: :clap:
