Dinos22 & Chew* :
With all your expertise on the AN8's, I wanted to ask you some questions about the Bios’s - considering two different scenarios
Note the MB in question for both situations is the AN8 SLI version (though, neither will be running in SLI mode)
1) If one was to use a 4000+ SD CPU (along with 2 x 1 gb OCZ Plat ram) with just tweaked RAM timings and a mild OC (say about 220 HTT Max @ 1:1 -- albeit 1T or 2T does not matter either way; if 1T works Great! If not, 2T is fine), what bios would you guys recommend for a rock solid & stabile system?
I was figuring either Bios 14 or 15 in this scenario
2) If one uses a 3000+ Venice -- week 21 -- (along with 2 x 512 OCZ Plat rev 2 [TCC5]), and was expecting to do no less than 268 HTT (preferably 1:1 - and expecting to use 2T timings to avoid any problems), what Bios would you both suggest for a stabile high performance oriented system for 24/7 use?
BTW: any experience and / or feedback on using Tic Tac's Bios based on Bios 13?
Thanks in advance for you input. BTW: my AN8 SLI should be here by Wed / Thu this week. So just wanted some input & see what you both think before I get started.
Tanks!
:toast:
