Behind the MOBO.
You will likely have to cut the wires and extend them.
Behind the MOBO.
Here is my rig:
http://img124.imageshack.us/img124/9...8xs5ac6.th.jpg http://img48.imageshack.us/img48/933...1qo9su0.th.jpg
C2D E6400
Asus P5B Deluxe
1GB OCZ Gold
XFX 7600GS
that boxedcooler. :slapass:
I know:doh:,but i will be moving to water soon:p:
water is good and cool. :up:
am i seeing ur top hard not installed correctly cause it is interfering with ur vga ?
Its installed right, but the PCI-E slot is low so i gotta put the HD at an angle for all 3 to fit heh.
Just bought the Lian Li expansion bay tho, so im gonna move the drives up to the 5.25" bays.
@ espionix: one xbox 360 next to the system. :slapass:
Today i decided to follow some advice of Highland3r and take my pc out of my case (that and my coolermaster atcs-201 is 5 years old and its showing its age a bit (4*80mm fans))
Here is the results
http://img14.imagevenue.com/loc741/t..._122_741lo.jpg
http://img9.imagevenue.com/loc1093/t...122_1093lo.jpg
http://img23.imagevenue.com/loc872/t..._122_872lo.jpg
some *shudder* SilenX fans blowing air over pwm's and RAM
http://img121.imagevenue.com/loc916/..._122_916lo.jpg
ive since added a 80mm fan to the side of my 120mm fan on the TR HR-03-Plus to cool the pwm's and anthing else that isnt covered by the 120mm.
http://img18.imagevenue.com/loc952/t..._122_952lo.jpg
All in all, ive shaved off 5-7 degrees off the full load temps!
Roll on TR IFX-14 and the lapping of the base / cpu
ive also just ordered two silverstone FM121's. one for cpu and one for gfx :D
Hehe, it's pretty much a Gears of War exclusive console :P
^^ What a hunk of crap.. :)
http://img528.imageshack.us/img528/6991/img7179ls4.jpg
my system with an 7800 gtx top from asus. :up:
here's my pc (if you can make it out :ROTF:) thermy armor case
http://img169.imageshack.us/img169/6167/dsc00135db5.jpg
custom silenxtrememaxlinetrio4000z™ fan mounts
http://img181.imageshack.us/img181/3696/dsc00132zc8.jpg
http://img53.imageshack.us/img53/2842/dsc00119ye3.jpg
Not just me eating at my PC :lol:
just got my Scythe Ninja Plus Rev.B gonna take some pics :) + SilenX IXtrema 120 90cfm fan =)
http://img90.imageshack.us/img90/4160/apr290001zj4.jpg
http://img361.imageshack.us/img361/581/apr290003lk1.jpg
http://img240.imageshack.us/img240/4...n010005we7.jpg
http://img240.imageshack.us/img240/5...n010006vc3.jpg
http://img240.imageshack.us/img240/5...n010007pi5.jpg
http://img391.imageshack.us/img391/576/jun010008ap8.jpg
http://img479.imageshack.us/img479/3...n010009ht3.jpg
Silenx... *shudders*
what does this mean? good or bad?
