Wow, u r lucky with those chips! Had 4 so far and best I can get is 52x lol!
I've seen "Dumo" post that 57x and up (provided the chip is capable) seems to require some kind of "cold" cooling for benching purposes so I'd be interested to know if the chip can bench 56x on water and or if you can get into windows at 57x? What is the max multi for the chip with PLL overide disabled? I also think you are going to like the MIVE. :up: I'll look forward to more results from your new combo.
i told you asus is better:p:
told you the ud7 suks:yepp:
found a chip same batch as yours but i too bored with sandy to buy it
well on my UD7 boot at107bclk was easy here i dont get the skews now but i will
for now im happy with this
http://img42.imageshack.us/img42/844/pi3q.png
Uploaded with ImageShack.us
btw new bios sux 1902
my USB ports dont work, and stable benches gone...maybe its me but 1850 its a keeper
one thing i dont like is that all area around CPU gets hot that doesnt happen on the UD7, while benching i mean
cheers
Sergio
it would be very nice if ASUS can update efi BIOS on the profile OC saves...that one can save settings to a flash drive and also selecting the profile not the way that is now putting 1, 2 or 3
cheers
Sergio
He,he Sergio don't post all bad things about ASUS!
i will for sure still couldnt get pass 101 bclk on the mive while my asus do 107 lol but i have to admit that this board is fantastic, regulation is awesome and boots 2 times faster than my UD7 so fast man cant believe it
love both boards either way i got a good UD7
cheers mate
Sergio
for sure i will do a nice face to face on them
for now what i see is
MIVE and UD7
amazing efi bios - normal bios
voltaje regulation amazing - using F3H i have no problems but UD7 takes way more volts
HS near CPU heats a lot - NOT ON UD7
boots like a ferrari - UD7 not its slow at post and boot
small increments of volts on all - UD7 has big jumps
just 1902 gave me problems - UD7 all but F3H
so far thats what i found for now
cheers
Sergio
testing the system :)
http://img143.imageshack.us/img143/7168/p1100485.jpg
http://img33.imageshack.us/img33/426/p1100489.jpg
ok guys i will bother a lot as im new lol
tell me it tried my SLI of GTX580 on the NF200 and on native, well native takes my SAME OC i had on NF200 with more vgpu but SCORES MORE
this is on native (on native + NF200 takes 150+ points less)
slots 1 and 3 for me score better i think i heard this if u can confirm me will be awesome
http://img829.imageshack.us/img829/9...1198022001.png
cheers all
Sergio
Awesome cpu and mive there Andre:up:
Dunno about Z68, but with my B3 MIVE (old bios) maximum multi bios boot was 56X.
For 57X~59X I have to set turbos manually in bios to 57Xs
As long as boot posted past "AE" on post code reader then it good to go with multi you set in bios (same as "4E" on UD7)
well
swaped the UD7, MIVE took place now, have to cut 2 tubes as socket its 1,5cms to the right but all went good
http://img20.imageshack.us/img20/1041/p1100587t.jpg
my 24/7
http://img818.imageshack.us/img818/2121/5ghz1png.png
hope you like it
cheers to all
Sergio
Back on track now after switching from UD7 to MIVE , after reloading and all im happy . . even though this board is almost same with v core per oc , the llc control is much much better . . posting some shots of my 24/7 prime pass , so for meantime the v core looks high , but for 3d benching and memory benching all i need way less v core .
Was the switch worth it ? Hell Yea this is the 5 reason why I think " opinion " :up:
1. Overall better support of board , bios updated regular
2. For me memory stability is better , board is way less stressed at 2133 cmd 1 , makes figuring a stable overclock a breeze
3. Run lower vcore idle cuase llc control is much better , no silly 1 - 10
4. pci express lanes have more space for multi gpu " no more hot crossfire sandwich " which ud7 sacrificed a space for a outdated legacy pci
5. rog overclocking from remote devices iphone android laptop , now i overclock while at work and i can reboot main pc from remote rog thru team viewer on bsod probelms
Bonus : Hot ass looking board red mania lol , lot of light's if thats your thing :clap:
http://i84.photobucket.com/albums/k7...MYSETTINGS.png
http://i84.photobucket.com/albums/k7...e/Untitled.png
http://i84.photobucket.com/albums/k7...e/IMAG0035.jpg
http://i84.photobucket.com/albums/k7...e/IMAG0044.jpg
