One question: What would the ideal (Problem Size) value to test only the processor into LinX? Thanks!
Hey, I've got a new entry....this one really suprized me. It's been in my daily rig for over a year, and I always though it a bit of a dud that ran too hot. Well, that may have been true on air cooling. But I threw it under water to test it for it's future owner and found it to be a very solid chip with proper cooling. The new owner will be happy :up:
batch # - 3851A231
mobo - Classified E760
cooling - FFF&FM
Vcore @ 1.5V - LLC enabled
http://i161.photobucket.com/albums/t...len/LinX01.png
4500 under watter is good
Xtremely nice submissions, guys! :up:
miahallen, I have a question for you.
There is another submission of yours with this chip (I presume), but with a higher CPU clock:
The last submission is of course very impressive due to the casing and limited cooling you used. So what would you like me to do with it? I can replace your old one on the list, if you like. Or add an additional entry to the list. Or just leave it alone. Your call. :)
You are bound to be stressing memory either way. You can not do much about it. Just use lowest memory multiplier and relaxed timings to reduce the stress.
zalbard....NBD for me either way. I say leve up the bigger number. To someone stumbling accross the thread, it's a more impressive number I think ;)
| 1.5125V | ASUS Rampage Extreme | Vapo LS Phase |
http://img87.imageshack.us/img87/6941/47ghz.jpg
http://img692.imageshack.us/img692/6472/47ghz1.jpg
That's a really nice E8400! What were your temps?
And welcome! :D
It seems like LINX doesn't really stress the GT's as hard as Prime does with HT is enabled. 6C/12T
Edit: Just downloaded the latest with updated binaries. Trying them now, Hope I succeed
CPU: Core I5 -750 #L006C024 @4507Mhz
M/B: ASUS Maximus III GENE
VGA :Galaxy GTX260
Ram: G.Skill RH 2000@1717
Power Supply : Tagen BZ800w
Case : HAF922 Fan CM90CFMx2 + Delta AFB1212SHE 1.6Ax1
Cooling : Water Cooling [ HK3.0LT + P655 + BI XFlow gt240 + Fan DeltaAFB1212SHE 1.6A X 2 ]
Room temp 20c
V.core 1.56875v / IMC/VTT 1.431v / PLL 1.8v / V.RAM 1.56v
http://upic.me/i/kg/g4.5g.png
http://upic.me/i/im/4507mhzlinxpass.png
Hello, Zalbard :) first of all, many greetings and thanks for your diligent work on this thread :
XEON W3520/batch 3848A352 / ASUS R3E BIOS 0802 / custom WC-
HHPS+ pump ,2 radiators , XP Fluid Pro
http://www.abload.de/thumb/4.5ghzlinx0802u6mm.jpg
http://www.abload.de/thumb/4.5ghzfinal0802huho.jpg
What could be wrong with what I write error
http://www.shrani.si/t/3O/g5/2oiwR3tP/fgdfhdh.jpg
I have i7 980x 4.5ghz, 1.4V and HT is on. I have Corsair Dominator gt 2000mhz 8-8-8-8-24!
Can you post e-leet so it shows your volts ! it is prolly vtt.. in my experience when linx stops after 1 loop mostly up vtt a notch solves it
I grew Cpu Vtt +300mv. Now I have a problem with the memory!. In bios I have the DRAM Voltage 1.52V, maybe this is wrong!
http://www.shrani.si/t/X/3z/46E6adB1/uhuuuuuuu.jpg
I am not in the settings nothing worked! I made only on the ALL and press START!
Hi,
double channel- temps were 61-62 - like that, but I do not have MORA etc "supercooling " , just two radiators.
Batch is 3848A352 , :)
Hi,
could you, please, add me to the database ?
PS: maybe I have posted too "tiny " screenshots :D
Great, thanks :)
