@Shazza
Good job man i like the blue theme ;)
@Shazza
First time watercooling....
CPU: i7 920 @ 4GHz w/Alphacool Yellowstone
GPU: GTX 295 w/Watercool Heatkiller
MB: eVGA Classified 760 w/Bitspower MOSFET/NB/SB blocks
RAM: 12GB Corsair Dominator 7-7-7-20-T1
PUMP: 2 MCP655 w/Bitspower top and mod kits
HD: 1 3.5 HD, 1 SSD Intel 80GB
Optical: LG Blu-ray
Radiators: 1 Feser Monsta, 2 240mm XSPC
Tube: Danger Den UV White
Fittings: All bitspower + 2 Koolance 45's
http://home.comcast.net/~n.ith/Water...g/finish06.JPG
http://home.comcast.net/~n.ith/Water...g/finish05.JPG
http://home.comcast.net/~n.ith/Water...g/finish03.JPG
http://home.comcast.net/~n.ith/Water...g/finish02.JPG
There is no way those little 25mm fans are sucking anything through that massively thick radiator...lol.
hey nzone, i see your computer there, that monsta may not be enough... i suggest putting another one on top there, just to drop another 1 or 2c... (if you cant pick up the sarcasm then i dont know what so say)... THOSE MONSTA's ARE HUGE!!! nice build :UP:
and yet another monsta! :D
http://img24.imageshack.us/img24/162...test001001.jpg
@Ridney that's badass... It looks like a dump truck hauling a dumpster. Very very nice!
Wow ridney, awesome rig! That monsta dwarfs your case like it's a micro tower!
my new setup :D on Corsair Obsidian
800D vs tj07 ^^
http://img25.imageshack.us/img25/846...zzzzzzzzze.jpg
Config
intel core i7 @ 4.2ghz
3 GO Gskill DDR3 1600mhz triple channel
SLI 8800GTX XFX @ Ultra
Raid 0 SSD Ocz Vertex Series
raid 0 raptor X 150GO
1 TO F1 Samsung
X-fi Extrem Audio
MSi X58 Eclipse BIOS 1.7
Seasonic M12 700W / bench 1000w sur Tagan
case Corsair Obsidian 800D
Watercooling
1x 360 - Black ICE GT XFlow
Laing DDC ultra 12V
CPU wb EK Supreme BLACK
x2 wb EK-FC8800
1/4 Coiffe 10/13
TYGON Black R3400- 10/13
EK-Multioption RES 250 Rev 2
PrimoChill ICE Non-Conductive Liquid Cooling Fluid Blood Red
OC
base clock 201x21 4200mhz @ 1.49v (+0.260)
ratio ram 4 > 1600 1.65v
qpi voltage +0.120
qpi > full speed 4.8 GT
intel eist > enable
intel turbo boost > enable
spread spectrum > disable
IOH voltage > 1.14v
ICH voltage > 1.3v
fix pci 33.7
http://img2.imageshack.us/img2/6482/dscf0303d.jpg
http://img297.imageshack.us/img297/1...tre4jpgeee.jpg
http://img19.imageshack.us/img19/331/dscf0326l.jpg
http://img2.imageshack.us/img2/3801/sanstitre5vj.jpg
http://www.pc-assemblage.fr/forum/viewtopic.php?t=2455
Awesome mate, best Corsair setup I've seen yet :D
I'll get another amd board for it. ;)
@ Ridney!
WOW what a rig! the first thing that came to my mind when i saw the mounting for your monsta Radiator, is: Does those four screws hold that entire weight?? :O Simply massive..
i also like what you did with the red sleeving in there ;-)
Good lord thats a huge radiator... impressive build!
Now someone needs to get one of those mounted -internally- :D
BlackHouse, the 800D is an awsome case.
It's the only one in recent times that entered my list for a possible substitute of my CM Stacker.
You passed from a tj07 to the 800D wrigth ?
OK I know the water looks a little yellow Im changing it tonight. I built this about 4 months ago just now getting around to the pics. Whacha think?
http://www.xtremesystems.org/forums/...&pictureid=835
http://www.xtremesystems.org/forums/...&pictureid=836
@rowland2004
[QUOTE=rowland2004;4041330]http://img.photobucket.com/albums/v3...g/IMG_0529.jpg
dude ...very nice,clean,nice lightning...i have same case and block.
@taylor-looks nice,do u have anymore pics???if so post em.
what watercooling parts u using?pump,res,rad,block..?
Ridney and BlackHouse......Very very nice. Well managed and very clean. :up:
It's ugly but it works
http://i74.photobucket.com/albums/i2...o/CIMG1541.jpg
Here is my newiest build planning on trying to throw this setup in a Raidmax Icecube case. Very very tight for a 2 x 240 rad setup.. But I am sure it will work. Here is my Danger Den Torture Rack build I finished last night.. Also here is a link to a slideshow----> H E R E
http://i274.photobucket.com/albums/j...k/IMG_3009.jpg
http://i274.photobucket.com/albums/j...k/IMG_3003.jpg
http://i274.photobucket.com/albums/j...k/IMG_3016.jpg
Here are a few more pics. pump is a ddc w/ek top and I used a D-fitting/w a koolance res. The rad is a swiftech MCR320 with med. yates w/custom paint. I orginaly had a XSPC RX360 which is why the rear of the case is cut out. But it was too big I had to mount the fans out side.
http://www.xtremesystems.org/forums/...&pictureid=843
http://www.xtremesystems.org/forums/...&pictureid=841
http://www.xtremesystems.org/forums/...&pictureid=840
Nice one, guys. Love the Torture Rack build, Lu(ky!
changed to internal radi. perhaps later will also attach the mora2 too :D
http://www.abload.de/img/img_22594brl.jpg
http://www.abload.de/img/img_2268b01i.jpg
The air disappeared already ;)
http://www.abload.de/img/img_2267h021.jpg
Waiting for new PSU ;)
