will gigabyte do a bios for the x6 cpus for this motherborad?
GA-MA790FXT-UD5P - BIOS F8f - 06.Apr 10
-Support for AMD X6 CPU
yeat thats right , i have a litle thing bothering me that is the fact that even the new bios for the UD5 says on the CPU suport list 1055T and down does not mention the 1090T ! is this bios for suporting all X6 cpu whith this steping (incluiding the 1090T) ?
cheers
I got this info only:
-Update AGESA 3.7.0.0 for AMD 6core CPU
sweet ass dudes, most probably there is no problem for 1090 also, only cause chipsets OC worse, that doesnt mean it wont support stock or even clocked settings
can someone please send me a x6 CPU to try it now?
ok was any one installd this bios yet !? becouse my specs on the sig are whith 1.42Vcore and 1.160 on the NB for going 3.0 on the NB and 4.0 on CPU i need 1.5 on Vcore and 1.280 for on the NB
and now its doing 4.0mhz at 1.47 vcore and 3.0 at NB 1.180
i did 25 loops at crysis bench 1920X1080 16XQ DX10
and about 20 minuts of prime and no crashes what so ever
gona do some tests and post something
this new bios is working fine
for me
I'm using it from yesterday, upgrade from F7, besides cpu core control from F8c no other difference to report, everything looks and behaves the same but I did not spend much time with it
MA790XT-UD4P - F8d
-support for Phenom II x6 processors
-09.April 2010
(sorry guys,I don't know where to post)
great job stasio
the temps are the same but its HOT here in the last days and before its was freaking cold so it could be becouse of that the temps are the same
but iam gona do some more testing
I used the link to get the F8f bios here in this thread. I am able to run 4ghz @ 1.45v. I was running 1.5v with F3L. I couldn't update my OCZ Black RAM with the profile. I had to import the settings from a xml file I exported from F3L. This worked great and set the RAM permantly in the bios. Been Crunching at almost 24hrs on this bios so far. Seems pretty stable. Can't wait to put a x6 on here.
http://3800z24.info/Phenom/WCG-4.0ghz.jpg
Hmm, seems too good to be true tbh...
I know, but I have no reason to lie. Still rolling @ 1.45v. I did notice though, It will over volt for less than a sec every 5 minutes. Might happen more often, not sure. It goes so quickly. I tried to watch it and see if it was constant.
Wooooww much faster boot time w/ SSD drives now. Might be the new Agesa right? Using Microsoft AHCI Win7 64 standard driver.
