Originally Posted by
SergioRoadster
It's a very cool cooler, myself was thinking of getting that one or one of the thermalright's chipset coolers.
Could you tell me the NB voltage you're using when it gets to the 48-50c?
I check temps and voltages with pc probe II, but don't know if they are accurate, at least the CPU voltage and temp are the same as the ones on CPU-Z and Real Temp.
With the stock heatsink, prime95 on load, PC Probe II reports 46º with NB on 1.23v
Maximum temp I get is 55º with NB on 1.44v
I have 6 fans on my case, upgraded the window panel fan to a aerocool 140mm, but don't know if those temps are true, I'm no experten, but doesn't seems much temperature difference for 21 volts of setting change.
My RAM settings are all in auto, except the voltage and speed. At the 333FSB was with 2.04v and 1066MHZ as in the screenshots in the GSkill site.
On my daily 400 FSB overclock and 444 I have them on the 2.1v max.
