Originally Posted by
bluspikez
@ panheimer -
It wasn't that difficult for me to switch to the new bios with the actual voltages instead of the integers. Sure, it took some getting used to, but it was nice to be able to actually see what values other people are using and set em straight up without having to change em to "P7N" numbers. It sounds like you have cooling under control, so I wonder what else it could be. What kind of PSU do you have, and is it stable? (If it is the 1000w one in the sig, you wouldn't think that would be the culprit, but you never know) I'm sure you have probably already been through the rigors of finding the culprit of the stability issues, but figured id ask anyways. :rolleyes: Also speaking of the PSU, did you use the same one on the DFI board? If so, is there a possibility that it isn't stable and could be causing the errors, seeing as you said the DFI board wasn't very stable either? Also, seeing as you are running SLi, what do you have your nb and sb bridge voltages at? I know with my setup that I have to run the voltages a bit higher than others that are running a single card to keep stability. Anyways, I know I'm probably just pulling strings here, but I'm just trying to help out. :)
