Originally Posted by
justin_c
read his post again situman :P
Don't use TAT, it was designed for pentium M processors, so please do not use extinct software. instead use prime v25.4 and prime all 4 cores with small ffts, reading temps from coretemp (or speedfan, if you use speedfan, you must set a 15 degree offset for each of the cores in the settings for INTEL CORE).
as for the 6x issue, i have had that before with extremely high temperatures. look for a "disable temperature throttling" something like that in your bios.
use rmclock and go to Advanced CPU settings, then uncheck TM1, TM2, and extended throttling, then apply.
