BTW, I have left most all the other voltage settings on Auto except the Vcore.
give us some screenie when you get it going
rich
Okay then - you need to do some tweaking but you need to understand what you are doing rather than monkey see - monkey do -:confused:. That way you learn nothing and could damage your system :eek:
Read theses overclocking guides to get some background knowledge
http://www.clunk.org.uk/forums/overc...beginners.html
Pk5 add on http://www.clunk.org.uk/forums/overc...s-p5k-add.html
Explanation of what settings do - for a P5E3 but similar BIOS http://www.anandtech.com/cpuchipsets...spx?i=3156&p=4
Once you have read all that grasshopper you will be able to overclock like a master :up:
These links and examples of BIOS setting have all been posted before. I and others posted settings recently - search and ye shall find ;)
Guys ive finally gone from wireless to wired (wohoo!)
What port is better to use? Does it make a difference?
Marvel Yukon 88E8056, or the Realtek RTL8169?
Thanks :up:
im using the Realtek the Marvel Yukon seem to time out with my router but not sure which is better far as that goes what ever works best for you
Rich
I too cannot get the Marvel one to work (yes enabled in bios). So I use the Realtek port and never have any problems.
Thanks.
Using the realtek and it's working fine.
Probably a bit of a trivial question for most, but ive been on wireless on this PC for years. Finally took the plunge, bought a long cable (15m), and ran it through the loft, downstairs and into the room with the router.
think you will be happy with the wired over the wireless
Rich
img link fixed, lol
didnt know it was broke
Rich
I will fill in my sig once the rig works ;)
For the moment :
P5K Premium Bios 504
Q6600 G0 lapped @ 3600 (9*400)
Thermalright Ultra 120 Extreme + 2 Akasa Amber @Push/Pull
4*1Go OCZ FlexXLC 1:1 4-4-4-12
Jetway 8800GT stock
Corsair HX620
RaptorX
-> minimalist rig for now
NoCase, the mobo is put on a box in a corner of the room and under a shelf.
Airflow = 0 , except CPU heatsink :/
So, i recall my issue : OCCT will lead to shutdown after 15'. It seems not to be CPU nor memory instability, neither chipset. I thought to mosfets over-temperature protection.
What do you think about it? Does this mobo have this kind of feature?
Gonna have a try ;)
I hope this is the key, so i can move on and get the rig watercooled :)
EK Waterblocks are also charming :D
EK 03a *2
MCW30 *2
Not too expensive and totally noiseless!
I want the power and the silence! :)
lol, well they may be "charming" but they don't do much when they aren't installed.
ReverendMaynard for got to thank you for helping me with posting the screenie so thanks i own you one for sure :up:
couldnt wait any longer just had to try bios 0504 out since im planning on going with e8400 or quad later on its working good so far got my clocks back the way they were so alls well so far
Rich
Tested the 0504 bios for a few days with an E8400. Bios was stable with this chip, but after I sold it and put the X6800 back, computer often refused to POST when changing something in bios. No pattern, just random. After a clear CMOS comp would post again - very annoying..
Did a downgrade to 0404, following TinTins guide earlier in this thread. Comp is now stable again.
So my advice is to upgrade the bios, ONLY IF YOU ABSOLUTE NEED TO.
im running my e6700 es with the 0504 bios for some days now no problems at all boots every morning clocks the same as before i did set defualts before flashing then cleared cmos after flash then set defualts again rebooted and set as i wanted
Rich
i have been run an 8400 with both 0504 and 0404 bios (now with 0404). they are both very stable.
the advantage fo 0504 is it gives you .5 multiplier, but on the other hand, i found it overclocking memory much worse than 0404, and 0404 gets higher scores in memory bandwith test in everest..i can run 4 sticks of 1G d9 at 1090 5-5-15 with 2.10v with 0404, 8 hours prime and memtest stable. but couldnt even boot beyond 950 5-5-5 with 2.10v with 0504.
