No, it was the newest driver.
good news on the power connectors front as kinc says you can use 2 6 pin pcie connectors if you don't have the 8 pin available and i think we can safely assume kinc knows, if you no what i mean ;)
heres the link
http://www.nordichardware.com/forum/...=8433&forum=28
and weŽll see some game benches tomorrow
http://www.imagebanana.com/img/kakz75n3/Unbenannt.JPG
Yes, the scheduler is important. In the G80 it runs at half the shader clock, so there are latencies involved here. The scheduler assigns a thread to a streaming processor. Of course it's more efficient to have the scheduler run at the same clock as stream processors. I'm not sure how big the difference is though. If the scheduler can assigns two thread to one processor then the penalty is rather small. I don't know enough about the G80 architecture to tell you about the latencies involved.
I have no information at all regarding the scheduler of the R600 to tell you how it is compared to the one in the G80. The architectures are so complex and different from each other that from specs alone it's hard to pick the better one. Only benches will tell the truth after both companies have had time to optimize for DX10 (and ATI for DX9).
All those features and converters, but they won't deliver an 8pin pcie powerconnecter with the HD2900 :stick:
NEW World record
beyond3d results
:thumbsup:Quote:
Very interesting .... R6 Las Vegas ,
R6: Las Vegas, maximun settings
2900XT/8800GTS:
1024x768
min:38/27
med:74/60
max:111/95
1280x960
min:26/18
med:53/42
max:83/68
1600x1200
min:19/13
med:37/30
max:70/48
http://forum.beyond3d.com/showthread...39173&page=213
link doesn't work for me:mad:
R600 buyers said that the 8 pin adapter is NOT included in the Retail box. Where the heck are we gonna find this adaptor?
yup thanks!:)
no real need for it, 6 pin on all pci-e
connections in single or crossfire is just fine....;)
http://i86.photobucket.com/albums/k1.../HD2900XTs.jpg
http://img242.imageshack.us/img242/6...ossfireui3.gif
with the 2 6 pin pcie power connectors can you overclock and do you have to use the amd gpu overclocking tool to overclock them as i can't see the overdrive overclocking facility......thanks
From http://www.elitebastards.com/cms/ind...1&limitstart=2 :
We've already mentioned the scheduler present alongside every cluster of sixteen Stream Processors - As well as this there is also a global scheduler present in G80, which oversees the graphics core as a whole.
dynasty but you need the 8 pin to have Overdrive in CCC and to overclock right???
regards
http://www.nordichardware.com/forum/...tml?highlight=
Scroll down, I think Kinc mentions something about the 6 pin. I hope this was the answer you were looking for.
Kinc from my understanding is only using 2x 6-Pin Connectors with his OC's. Only real advantage of the 8-Pin is well ATI says its safer for OCing, but it adds 2 grounds to help with the extra current to the card.
