I agree in some degree. My watercooling temps are the same whether the pump is insatiably loud at high, or at the air is louder 1.
That's very red :).
I am glad you are happy with your temperatures.. I don't see why you use SO many elbows though. Why do you use them in places that they aren't needed at all? Elbows are supposed to be used only when 100% necessary.
Finally redid mine. Still crappy wire management.
http://i275.photobucket.com/albums/j...p/DSCN6336.jpg
http://i275.photobucket.com/albums/j...p/DSCN6335.jpg
All you guys :banana::banana::banana::banana::banana:ing at NaMcO for the elbows really should try using the fittings and tubing he is before opening your mouths. PUR is much stiffer than anything the "barb" or "compression" crowd uses. It feels nice and flexible outside the case but then it does something weird when you try to put it in......it doesn't bend very well......how do I know? It's what I use for most of my builds.
http://www.xtremesystems.org/forums/...postcount=9056
@ Freebo
Great case great desing
@ l33t p1mp
More wire managment pls... :D
@Freebo
I was watching your pictures from the bottom and thought "ohh im not the only one still using this aged dfi lp4 mb", then I looked at the note and the "Koen Server" made me confused lol :lol2:
Btw Its my first post on these forums so Hello Everyone :up:
Here are some pics of my current setup:
http://img79.imageshack.us/img79/277/chief1pu1.th.jpg http://img68.imageshack.us/img68/8025/chief2ds2.th.jpg http://img68.imageshack.us/img68/2858/chief3nm3.th.jpg
http://img172.imageshack.us/img172/5...ief4ij1.th.jpg http://img230.imageshack.us/img230/786/chief5fo3.th.jpg http://img155.imageshack.us/img155/4...ief6hh9.th.jpg
http://img267.imageshack.us/img267/3...ief7vp3.th.jpg http://img70.imageshack.us/img70/6679/chief8mb0.th.jpg
Looking good. I like how you mounted the rad. :up:
[QUOTE=Koen;3129385]@Freebo
looks great :welcome:
That's why I like Chieftech cases
@ Koen
Very good build and can I ask what is your pump? :)
Central heating . .. . . what's that? I'm glad it never goes below zero here :D.
I like the look of the pump in question. Send it to Martin lol
Im really confused but oh well, the Pump in Koen Server is a 12V Laing DDC-1T Pro 10W with the XSPC Pumptop/res. Basicly all Koen Server is is my old case with a load of my old components (from when I had my S939 stuff) its a little side project ive started after doing my Koen CCXR project.
I don't think they were talking about your build mate :D
Freebo - look at the post #9686 :)
Thanks for comments :)
The pump is a hot water service pump as rafwlkp said. Without my "mods" it looks like that:
http://www.cerpadla-neptun.cz/media/...1168931920.jpg
Such pumps were pretty popular here in Poland before 12V Laings came in. Some people still prefer them because of their high reliability and very low noise (comparable to MCP655 at first gear).
Low noise <3.
Ugh but then my next complaint would be fans. . .
Was the pump expensive?
In Poland it cost ~100$
Someone, I beg you, please help me with my horrible wire management! I hate this case, wire management - horrible with it.
Any links where to find that pump? Seems to be interesting..
ah finally i received the mb brace for my ascension...so i can finish the last steps.
found a lil laing ddc and a pa160 during tidying up...could be a funny fifth loop for the mips mem cooler doen't it :D
Check this one, same case
http://img502.imageshack.us/img502/6...5081758ha8.jpg
