I had one that was only good for 2.63 with 1.63 volts on XP90... and it was week 17 too.
AMD 64 3200+ lbble 0519 is good OCer?
10*300??
I've seen some decent week 19's but nothing super good
they can do 3GHZ? (10X300)
on DFI nF4 ULTRA-D & G.Skill FF???
No cpus are the same, so you won't know until you try it if you got a good one or not. :fact: You can increase your luck going with a week that is known to have good cpus, but some can be really bad also. Good luck :)
I have a qustion for you guys.. Im getting a 3500+ venice next week. Its a 0519. I wanted to know if this is a good clocker and if one of you gys has any experience with this week. Also I wanted to know what will be a good aircooler for my cpu:
Coolermaster Hyper 48
Coolermaster Hyper 6
Thermalright XP-90
thermalright XP-120(but does this one fit a MSI K8N Neo2 or dfi ultra d(nforce3))
Regards
YOu can also add the ThermalTake BigTyphoon on that list.Mny people and reviews claim that it is hard to beat
And Scythe Ninja can be added to the listQuote:
Originally Posted by JfRsQ
I think i just made up my mind... It will be a xp-120 with a delta 190CFM 120mm fan.. The only thing i wanna know is if the xp-120 will fit a dfi unltra-d nf3?
afaik, yes.
Thx mate btw. I finally got my cpu. After some quick testing i was able to do 2.7Ghz prime stabel.. But the 12 V line was dropping to 11.4 every time it was beched. So i can go higher with my own psu i think.
Regards
how are these new chips clocking? I still using an old 1700+ :D but i need to upgrade to something a little quicker. Should I expect 2.8ghz 24/7 aircooled out of a 3000+ E6 venice? I'd probably get it from newegg. hah a 1ghz overclock ;) just like this old 1700+
Hello!! What Can you tell me about this Stepping ? 3800+ Venice
ada3800aa4BP
lbble 0524 EPMW
z707522f50961
Thanks!!!
have in mind to buy wether a P M 740 or an A64 rig....
could you help me make my mind
So i've chosen a 3000+ Venice.....then maybe an X2...the shadow knows.....
Then 2x G.Skill Kit Extreme 2 x 256 Mo PC4800 (so 4x256....because Venice Core does have Dual-Memory controller..... :)
But the mobo...aouch????
I've seen that you guys are running :
DFI LanParty UT nF4 SLI-D (Active cooling)
DFI LanParty nF4 SLI-DR (Active cooling) 360 HTT
MSI K8N Diamond 54G or K8N (Active cooling)
But no :
Abit AN8-SLI (Passive cooling)
Abit Fatal1ty AN8-SLI (OTES system and Active cooling) 330 HTT
Asus A8N-SLI (Active cooling)
Asus A8N-SLI Premium (Passive cooling)
Gigabyte GA-K8N Ultra-SLI (Passive cooling)
Those cards may reach 300 HTT but no one is using them...Why??
CG would be watercooled Sapphire X800XL PCI-E
Cooler Master aquagate modded
active Tower cooling (just what it says....not much more to tell about....self-studied...)
This rig would be for OC and games......
I'm planning to reach 2,6 Ghz....2,8 Ghz.....but only 24/24h results....
I know a little about AMD OC methods but i'll learn and already have a little...
Of course....as soon as they will release lower freq. San Diego... :p:
Question : has AMD planned a 939 socket version of the Sempron 64 (with 256 L2 cache and X86-64....and SSE3....) ??
Also : have read a spec compare status....A64/A64X2/Dual-Opteron/Opteron Dual-Core....
It seems that memory bandwidth is doubled when using dual-Opteron instead of A64X2 (2x1024 L2.....so 4400+ or 4800+)
also, you need a proper board.....Socket 940
Asus K8N-DL ??
also ECC memory sticks
I can buy a San Diego 4000+ for 380€ (i can hope for 2,9 Ghz...more than an FX-57..on water :D )
....but i don't know if that's a realisitc choice......an X2 would allow me to take my rig a couple of years further....
also, i'm waiting for ram disks.....damned.....they would be fast...:)
So heres my little Baby. Mobos Limit is reached und not so stable.
http://img99.imageshack.us/img99/64/...vc1m9vk.th.jpg
Venice3000+
YBBLE 0523CPGW
337*8@1.65 at this crap mobo:
gigabyte K8NS-939 F7 bios now
custom gas bottle w/compressor cooling
cpu-z id: 30607
didnt manage to take any more shots cause bottle began leaking
=>dangerous!
anyone else get any of the total crap E6 venice's ? mostly the 3200 or higher ?
ive seen other besides me post that they cant get past 2.6 stable even running 1.7v which is just horse pucky if you ask me.. but oh well... life goes on
I had two E6!
One was 0523DPCW was stable at Stockcore up to 2430Mhz.
The other one was 0528GPFW was only up to 2300Mhz at Stockcore Primestable.
But both where very sensible and fast Freezing at Overclocking.
Heres my LBBLE 0517DPMW with an XP120+1800rpm fan.
http://upl.silentwhisper.net/uplfold...zsuperpi1m.png
Yep (as discussed via e-mail M8) was stable at sig now only does STD!!!!!!!!!!!!Quote:
Originally Posted by Lestat
3500winnie was the same too
my venice e6 0533 sucks bigtime on my neo2 platinum. MAX = 2600mhz 1.6
my venice 3000+
http://img186.imageshack.us/img186/8639/270060zv.jpg
weel this was on air coling, with stock cooler.
i wil try a big run, whn i am with water, and see if i get the 3.0ghz :)
I have a 0531BPMW E3 revision, it's crap.
It can do 2,7GHz with 1.65V but only with a divider or in single channel.
Only SuperPi 1M stable though.
Stay away from these.
LBBLE 0517BPMW thats mine, it has gave 2.7 with 1.5v
I got stuck with a dud Rev. E 0524 that cannot get above 280.. dividers won't even work.
