4 Attachment(s)
Alternative nF4 cooling @ DFI SLI-D
My first post.... Some people has been discussing how to fit in an alternative nF4 cooler than the crappy default one. Unmodded my chipset run at 42-45 degrees, even higher during oc. Since I have a 6800 Ultra with reference cooler blowing hot air right on top of the nF4 chipset I started by cut out a curved bit of plastic(from an icecream box) :D . Put it on the end of the 6800 over the nF4 so it directs the air up instead. That lowered temp with about 2 degrees. Still not happy I ordered an Revoltec VGA/Chipset Type 2 copper cooler, the one for GeForce4Ti 4200-4800 SE/GeForceFX 5600 Ultra. I had to to drill new holes for the vinyl mounts(52mm apart) and file down a couple of mm of the coolers edge at two places. Near the capacitor and near the crystal. Check out the pics. Now nF4 runs at 34 degrees idle and 36 degrees full load...max overclocked! :banana:
And it runs much more stable. :cool:
