Originally Posted by I(illa Bee
Dose it post 2-2-2-5-1t, and fail in windows? Also that memory has Samsung TCCD chips on them, a lot of the time it dose not like voltage at all...try running it 2.6 or 2.65v. There are many that overclock way better on less voltage…I’m talking 260+ on only 2.65v…so give it a try..
Also my board under volts my 90nm core a lot. So your CPU might not be stable at stock clocks, due to low voltage, try upping the voltage, My BIOS reading were accurate to what my multimeter told me my CPU voltage was…
Yes, it posts with no problem... and yes, it fails in Windows when running the aforementioned test. The only reason I was giving it voltage was because the packaging actually states "Test results using 2.75v". I'll try to reduce the voltage to see if that helps, at all.
Ummm… you have a 3200+ the stock multiplier is 10, you cant go higher, than 10, and you CPUs stock speed is 2.0Ghz, not 2.2, and no one is guaranteeing you a free 200Mhz. Also again, go in a look to see what its reading you CPU voltage as.. Ill bet its a lot lower than 1.6v, I have mine set to 1.55 with the +10% and I only get like 1.63v, I cant remember......
No, I have a Winchester 3500+.. the stock multiplier is x11. Let me know what your CMOS settings are for these items. I'd be more than curious to know.
