thermalright ultra extreme = teh w1n
hey guys, new to the xtreme forums, but here is my rig!
http://www.overclock.net/gallery/dat.../computer7.JPG
thermalright ultra 120 extreme
thermalright ultima-90
tuniq tower 120
Scythe Ninja B (Plus) new revision
Scythe Infinity
the scythe beat all of them because its rated Silent PC .. check out silentpcreview.com cools + silent .. im gonna get a scythe ninja b + silenX 120mm fan 74cfm 18dba ..
Heatsinks don't make noise, fans do..
http://img522.imageshack.us/img522/1463/pchn9.jpg
TT120 on the CPU, NV Silencer 6 on the 7900GT
Hello.
I have thermalright ultra 120 extreme is a good cooling with fans Sycthe 1600rpm and too have cooling for memory thermalright hr 07.
Here some pictures:
http://img244.imageshack.us/img244/8...tadonq8.th.jpg
Greetings!
I'm gonna order the Scythe Ninja Plus rev.B easy installation
Six 120mm fans (not including the PSU Fan)
two 80mm Fans attatched to a pci slot card holder to flow onto the Graphic card
http://i104.photobucket.com/albums/m...2/DSC00755.jpg
Temps run very cool. Stock Cpu at idle is 31C, the Graphic card idles at 47C. What do you guys think? :)
Me thinks you should get a Thermalright Extreme. Get rid of the fan by your hard drives---it isn't doing anything due to the small holes.
Brendan
http://i104.photobucket.com/albums/m...2/DSC00753.jpg
(older pic of my case, before i did a bit of cable management)
My thought was because of the fan in the very front of the case blowing on the harddrives that it was probably not getting a lot of air so i thought to add another fan on the other side of the harddrive cage to help force air from one side to another.
I will look into the thermaltake extreme. Is that the full name of the heatsink? Or is it extreme volcano?
Some pics of my latest build for a friend:
The case has zero options to hide cables, so it doesnt look that clean, but I am very happy with the airflow. All components are in sime kind of airstream and the noise isnt really noise.
my new fileserver:
http://img398.imageshack.us/img398/4209/img6892jk9.jpg
^^ Neet
ask him to install the cables and lets see if neat will still be the best word for it ;)
fr3ak which case is yours?
The case in the pictures is a Thermaltake Matrix VX.
The case I am using is a Antec Super Lanboy, but I am in the process of getting a new big tower to fit 2 watercooling loops in it.
That thermaltake case was kind of okay. I wouldnt have bought it, but the owner of the PC liked it. The front fan is kinda noisy, because its humming, the rest of the case is solid and I like the meshed and open front which allows good airflow.
Pull out the metal plated behind and it will be better.
I want to figure out how to hide the cables on my antec 900 ..
I dont know which other case 17.5-18.8" inches tall i would of gotten because there were really none that beat the flexibility. HDD Cages made me get this case really .. otherwise I would of prob goten the TT MidTower Armor. but anyways the Aurora was on my list until I saw the price.
Those Tuniq look sick.. they weigh like 2lbs or 4lbs ? I forgot
I gotta start looking for prices on the scythe ninja plus rev B
